rtems_message_queue_receive
Chris Johns
chrisj at rtems.org
Fri Nov 12 02:21:43 UTC 2004
Ian Caddy wrote:
> I don't think the problem is at the ISR level, but that something is
> wrong with your tasks. The easiest way to check this is to see if the
> idle task is running at all. Put a breakpoint in the idle task loop and
> see if you get there once things go spacko.
> The other option is to just break using the BDM and check where it is in
> code. If it is always in a particular thread, then chances are it is
> hogging the processor and that lower priority tasks are not getting to
> run. If your tools contain profiling, then this will tell you where you
> are getting stuck, but the breaking the BDM every so often is also a
> good indicator.
Another tool is the Capture Engine. If you have the RTEMS monitor
running on a console you can enable the Capture Engine and see where the
task flow is going. The wiki has a page on the Capture Engine under the
Debugging Hints page or just enter 'Capture' into Find.
Chris Johns
