Dosfs question..?
Eugeny S. Mints
emints at ru.mvista.com
Thu Nov 18 18:11:10 UTC 2004
Eugeny S. Mints wrote:
> Thomas,
> Thomas Doerfler wrote:
>> Daniel, Jennifer,
>> this seems like a bug to me. I have looked into "unlink()" code, and
>> currently I really don't understand, why unlink tries to evalute the
>> permissions of the parent of the current directory.
>> When I want to delete the file "/mnt/ramdisk0/testfile.txt", it makes
>> sense to check the permissions of "testfile.txt" and of
>> "/mnt/ramdisk0", because if any of these two is not writable, a delete
>> would be illegal. But why check "/mnt" ?
> it is definitly something wrong some where but it seems to me that
> unlink() just checks permissions for the file you are going to delete
> and the directory which contains this file, i.e. file1 and ramdisk0 ,
> and this seems reasonable.
> Probably the core of the issue is that FAT root dir doesn't contain ".."
> entry, I'm thinking over this....
> Oops, seems found the bug in msdos eval code. The handling of ".." case
> in FAT root dir is right the next operation after the "if" statement
> which returns the error for Daniel.
> Daniel, please try to exchange these two "if"s and see what happen.
> (Unfortunately I have no up-to-date RTEMS sources in the hands).
Probably the better sollution is to add
&& (pathloc->node_access != pathloc->mt_entry->mt_fs_root.node_access)
to the "if" returns the error, i.e.
case MSDOS_UP_DIR:
* Only a directory can be decended into.
if ((fat_fd->fat_file_type != FAT_DIRECTORY) &&
errno = ENOTDIR;
rc = -1;
goto error;
This variant seems to me more correct while the code needs clean up anyway.
> Eugeny
>> Does unlink check the wrong directory? Or does
>> "rtems_filesystem_evalute_parent" check the wrong directory? Currently
>> I don't think that the MSDOS implementation is wrong here, although
>> there is no "." or ".." directory entry in its root.
>> Jennifer, can you help here?
>> wkr,
>> Thomas.
>>> -- In unlink()
>>> Rtems_filesystem_evaluate_path() returns fine.
>>> Rtems_filesystem_evaluate_parent() returns -1.
>>> -- In Rtems_filesystem_evaluate_parent()
>>> msdos_eval_path() (with ".." as path) here we go through MSDOS_UP_DIR.
>>> Returns an error (se below).
>>> /DANIEL
>>>> -----Original Message-----
>>>> From: Eugeny S. Mints [mailto:emints at ru.mvista.com] Sent: Thursday,
>>>> November 18, 2004 4:17 PM
>>>> To: Daniel Gustafsson
>>>> Cc: 'Thomas Doerfler'; rtems-users at rtems.com
>>>> Subject: Re: Dosfs question..?
>>>> Daniel Gustafsson wrote:
>>>>> Hi.
>>>>> I have debugged the unlink() and the error occurs in
>>>> msdos_eval_path().
>>>>> -- in msdos_eval_path(), line 114
>>>>> switch(type)
>>>>> case MSDOS_UP_DIR:
>>>>> if (fat_fd->fat_file_type != FAT_DIRECTORY) -->
>>>>> fat_fd->fat_file_type = 5 = RTEMS_FILESYSTEM_MEMORY_FILE = FAT_FILE
>>>>> errno = ENOTDIR;
>>>>> ERROR!!!
>>>> Well, the unlink(file) should not go through case MSDOS_UP_DIR.
>>>> Please, try to
>>>> debug why msdos_get_token() returns MSDOS_UP_DIR type for your file1.
>>>>> Steps to mount and create file:
>>>>> 1. msdos_format("/dev/ramdisk0", NULL);
>>>>> 2. ide_part_table_initialize("/dev/ramdisk0");
>>>>> 3. rtems_fs_mount(fs_table, sizeof(...), NULL);
>>>>> fs_table ~ { "/dev/ramdisk0", "/mnt/ramdisk0" , msdos_ops,
>>>>> RTEMS_FILESYSTEM_READ_WRITE, flags, 0 } --> example
>>>>> 4. creat("/mnt/ramdisk0/file1", S_IREAD | S_IWRITE);
>>>>> 5. write to file 1
>>>>> 6. close file 1
>>>>> 7. unlink("/mnt/ramdisk0/file1");
>>>>> Returns "NOT A DIRECTORY"
>>>>> Everything is OK but the unlink.
>>>>> NOTIS: The /mnt/ramdisk0/ doesn't contain "." or "..". If I
>>>> make a sub
>>>>> directory in /mnt/ramdisk0/ it will contain "." and "..".
>>>>> //DANIEL
>>>>>> Thursday, November 18, 2004 3:08 PM
>>>>>> To: Thomas Doerfler
>>>>>> Cc: Daniel Gustafsson; rtems-users at rtems.com
>>>>>> Hi All,
>>>>>> Really strange return code. unlink() call should transform into
>>>>>> msdos_file_rmnod() routine call. Check whether the msdos routine
>>>>>> is reached if not - the issue somewhere in non-msdos related
>>>> code (start
>>>>>> from unlink() routine in libcsupport dir).
>>>>>> How do you mount your msdos volume? I suppose you mount to some
>>>>>> IMFS directory (mnt?). My suggestion that the issue is somehow
>>>> connected to
>>>>>> the mount point.
>>>>>> Eugeny
>>>>>>> Daniel,
>>>>>>> I did a quick check of source codes, I really don't know what is
>>>>>>> going on in your system.
>>>>>>> My idea, what you might do:
>>>>>>> - Either step into the unlink call and find out where the error
>>>>>>> code is set.
>>>>>>> - Or: perform a grep over the libfs source code:
>>>>>>> grep ENOTDIR cpukit/libfs/src/*/*.c
>>>>>>> You will get about 10 results. Set a breakpoint on every of these
>>>>>>> lines. Start your code. And look where the breakpoint is hit.
>>>>>>> The rest is analysis then.
>>>>>>> By the way: which string do you pass to the unlink call?
>>>>>>> wkr,
>>>>>>> Thomas.
>>>>>>>> Hello.
>>>>>>>> I am running rtems 4.6.2 on a ERC32 using TSIM as simulator
>>>>>> enviroment. Am
>>>>>>>> using dosfs on the ramdisk. Everything works fine, as it
>>>>>> should, except the
>>>>>>>> removal of files. I try to use the unlink() but it won't
>>>>>> accept the file
>>>>>>>> (returns "NOT A DIRECTORY"???). What am I doing wrong. Is maybe the
>>>>>>>> permissions is f**kt up (does dosfs support permissions
>>>>>> because I can't
>>>>>>>> change them).
>>>>>>>> Please help me someone or direct me to some documentation
>>>>>> about rtems dosfs.
>>>>>>>> Many thanks to Thomas Doerfler for providing to the Rtems
>>>>>> community with a
>>>>>>>> functional format function for dosfs.
>>>>>>>> Regards
>>>>>>>> Daniel Gustavsson
>>>>>>> IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>> Thomas Doerfler Herbststrasse 8
>>>>>>> D-82178 Puchheim Germany
>>>>>>> email: Thomas.Doerfler at imd-systems.de
>>>>>>> PGP public key available at: http://www.imd-
>>>>>>> systems.de/pgp_keys.htm
