Network Configuration after BOOTP
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Wed Nov 24 14:19:22 UTC 2004
I turned this into the Wiki entry:
http://www.rtems.com/phpwiki/index.php/Obtaining%20Interface%20Information
Thomas Rauscher wrote:
>>-----Original Message-----
>>From: Kirspel, Kevin {Engineering - Osmetech}
>>[mailto:kevin.kirspel at osmetech.com]
>>Sent: Tuesday, November 23, 2004 6:23 PM
>>To: rtems-users at rtems.com
>>Subject: Network Configuration after BOOTP
>>What is the best way to obtain my IP address, MAC Address,
>>Network Mask,
>>and Default Gateway after the
>>rtems_bsdnet_initialize_network() call? I
>>want to be able to access this information from software.
>>Kevin Kirspel
> #include <sys/types.h>
> #include <sys/ioctl.h>
> #include <sys/socket.h>
> #include <net/if.h>
> #include <netinet/in.h>
> int get_ifaddr(const char *ifname, struct in_addr *addr)
> int fd;
> int rc;
> struct ifreq ifreq;
> struct sockaddr_in *sockaddr;
> fd = socket(AF_INET, SOCK_DGRAM, 0);
> if(fd<0) {
> return -1;
> strcpy(ifreq.ifr_name, ifname);
> rc = ioctl(fd, SIOCGIFADDR, &ifreq);
> if(rc == 0)
> sockaddr = (struct sockaddr_in *) &ifreq.ifr_ifru.ifru_addr;
> memcpy(addr, &sockaddr->sin_addr, sizeof(*addr));
> close(fd);
> return (rc==0) ? 0 : -1;
> should do the trick. 'ifname' should contain the name of your interface,
> e.g. "eth0", 'addr' then contains the result.
> Regards,
> Thomas Rauscher
> Thomas Rauscher
> LOYTEC electronics GmbH
> Stolzenthalergasse 24/3
> A-1080 Wien
> Austria/Europe
> trauscher at loytec.com
> www.loytec.com
> Phone: +43-1-4020805-15
> FAX: +43-1-4020805-99
> Networks under control!
> LOYTEC and NEC Electronics Join Forces in Building Automation!
joel at OARcorp.com On-Line Applications Research
