Easy DOSFS question
Bogdan Vacaliuc
bvacaliuc at ngit.com
Thu Nov 25 15:48:45 UTC 2004
Hello Everyone,
I've been busy over the last couple of months and unfortunately have been unable to contribute. However, I can offer some snippets
of working code we have used in other projects. As you can see below, Thomas is quite right, it is simply a walk of the free
cluster list in the FAT. The total space can be obtained from the boot parameter block.
[Excuse the RDCF-isms, but the code is fairly self-explanatory. It also suffers from the 2GB limit, sorry. You probably want to
report back size in logical blocks, and have a way of getting the block size, though it is generally 512 bytes.]
This information should be available to the filesystem driver. One could add an IOCTL or something.
Hope this can help.
Best Regards,
-bogdan
Function: rdcf_free_space
//! Return the amount of free space in the file system.
/*! \ingroup rdcf2
This routine Return the amount of free space in the file system, in bytes.
\return The amount of free space.
long int rdcf_free_space(struct rdcf *f /*!< A pointer to the FCB. */
rdcf_cluster_t cluster;
rdcf_size_t number_of_empty_clusters = 0;
//if ((f->result=setjmp(f->error)) != 0) return (long)(f->result);
error_init(f,long);
initialize_fcb(f, NULL);
for (cluster = 2; cluster <= f->maximum_cluster_number; cluster++)
if (FAT_entry(f, cluster) == EMPTY_CLUSTER) number_of_empty_clusters++;
f->file.size = number_of_empty_clusters * (f->sectors_per_cluster * SECTOR_SIZE);
return (long)(f->file.size);
Function: rdcf_total_space
//! Return the total amount of space in the file system.
/*! \ingroup rdcf2
This routine returns the total amount of space in the file system, in bytes.
\return The bytes in the filesystem.
long int rdcf_total_space(struct rdcf *f /*!< A pointer to the FCB. */
// rdcf_cluster_t cluster;
// rdcf_size_t number_of_empty_clusters = 0;
error_init(f,long);
return (long)(f->maximum_cluster_number-2) * (f->sectors_per_cluster * SECTOR_SIZE);
On Thursday, November 25, 2004 9:24 AM, Thomas Doerfler wrote:
> Hi,
> the basic task seems not so complicated: Any
> unallocated cluster hast the value ZERO in the FAT.
> So to get the number of free clusters, just scan
> through the FAT and count the ZERO clusters.
> The info in FS_Info is not SO reliable, and might
> not be available anyhow.
> wkr,
> Thomas.
>> Hi all,
>> Actually I'm not sure and unfortunately have no time right now to
>> investigate the issue in more details but whether the free_cls field
>> of the structure fat_vol_s may be usefull to implement the required
>> functionality?
>> Regards,
>> Eugeny
>>>> Hi Etienne,
>>>>> Hi Thomas,
>>>>> Is there a way to get the free space available on a DOSFS mount?
>>>> Easy answer: no :-(
>>>> Basically, you would have to walk through the FAT to find things
>>>> out. And there is no call to do things like that right now.
>>> At start of day, you may open dummy file and make binary search of
>>> maximum free space available by calling seek(,,SEEK_SET), assuming
>>> that no other file system activity happens. But this is kludge.
>>> Victor
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
