About AT91RM9200's EMAC driver
Yanjun Luo
yjluo at panjet.net
Tue Nov 30 10:02:08 UTC 2004
Hi, Lars
> The network driver in csb337 bsp assumes that you have a MAC address
> in the EMAC. Have you verified that U-BOOT puts a MAC address in the
> EMAC before loading rtems?
Yes, I set MAC address at the init.c before initialize the network.
and from running network-demos-4.6.2, I can see status like below,
and I think the config is ok.
I'm wonder why the interrupt is always zero, like my board never
receive a packet at all.
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
default 192.168.0.1 UGS 0 0 0 eth0
192.168.0.0 255.255.255.0 U 0 0 1 eth0
192.168.0.1 UHL 1 0 1 eth0
192.168.0.255 FF:FF:FF:FF:FF:FF UHL 0 18 0 eth0
************ MBUF STATISTICS ************
mbufs:2048 clusters: 256 free: 256
drops: 0 waits: 0 drains: 0
free:2047 data:1 header:0 socket:0
pcb:0 rtable:0 htable:0 atable:0
soname:0 soopts:0 ftable:0 rights:0
ifaddr:0 control:0 oobdata:0
************ INTERFACE STATISTICS ************
***** eth0 *****
Ethernet Address: 00:01:02:03:04:08
Address:192.168.0.144 Broadcast Address:192.168.0.255 Net
mask:255.255.255.0
Flags: Up Broadcast Running
Send queue limit:50 length:0 Dropped:0
Total Interrupts:0 Rx Interrupts:0
Giant:0 Non-octet:0
Bad CRC:0 Collision:0 Missed:0
Tx Interrupts:0 Deferred:0 Lost
Carrier:0
Single Collisions:0 Multiple Collisions:0 Excessive
Collisions:0
Total Collisions:0 Late Collision:0
Underrun:0
Raw output wait:0
************ IP Statistics ************
total ip packets generated here 3030
datagrams successfully fragmented 12
output fragments created 72
************ ICMP Statistics ************
************ UDP Statistics ************
total output packets 3030
************ TCP Statistics ************
> Btw, which version of u-boot are you using?
> http://mmd.ath.cx/csb337-boot/ ?
I'm using U-BOOT 1.1.1 (at91rm9200dk_config) ported by myself,
running from ATMEL's boot. and actually I just changed the code
about flash chip.
Regards,
Yanjun Luo.
On Tue, 30 Nov 2004 10:14:22 +0100, Lars Munch wrote
> On Tue, Nov 30, 2004 at 04:01:57PM +0800, Yanjun Luo wrote:
> > Hi Jay,
> > I just test AT91RM9200's EMAC driver from your CSB337 BSP.
> > I use network-demos to test it. Whatever TCP or UDP packet
> > I send, I can't catch it with sniffer. It seems that my board
> > have not send anything out.
> > My hardware is working because I use U-BOOT with TFTP to download
> > my RTEMS image, and it works smoothly.
> > Do you have any suggestions to test/verify it?
> > Anyone's any hints are welcome.
> > BTW, where can I find a ping(client) to test my system?
> > Regards,
> > Yanjun Luo.
> Hello Yanjun
> Regards
> Lars Munch
