timeout
Paul Whitfield
paulw at omnitronics.com.au
Tue Nov 30 23:59:02 UTC 2004
Steve Holle wrote:
> What are the units for the timeout value in the
> rtems_message_queue_receive routine are? I've checked the wiki and
> documentation with no luck.
RTEMS ticks... and you are quite correct, it does not state
that on the manual page. However, for all "classic" rtems calls
that block with a time-out parameter the time-out is in ticks.
See Key Concepts page in the manual on time for more information.
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.2/share/rtems/html/c_user/c_user00018.html
For more information about ticks.
And "real" time per tick is
CONFIGURE_MICROSECONDS_PER_TICK in confdefs.h
It defaults to 10 milliseconds per tick.
See:
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.2/share/rtems/html/c_user/c_user00376.html
Hope that helps.
Paul
