error 105
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Oct 1 11:03:22 UTC 2004
I recall that much of that memory comes from the C Program Heap
so make sure that you have plenty of memory assigned to it.
It's early and I am still packing so I hope I got that right. :)
--joel
Steve Holle wrote:
> I increased mbuf capacity and cluster to the values show below and the
> same problem occured.
>         struct rtems_bsdnet_config rtems_bsdnet_config =
>                 &netdriver_config,
>                 #if (defined (RTEMS_USE_BOOTP))
>                         rtems_bsdnet_do_bootp,
>                         75,
>                         265*1024, // Expanded mbuf capacity.
>                         512*1024, // Expanded mbuf cluster capacity.
>                 #else
>                         NULL,
>                         75,
>                         0, // Default mbuf capacity.
>                         0, // Default mbuf cluster capacity.
>                 #endif
>                 // See below for real example
>           NULL,
> // Host name.
>           NULL,
> // Domain name.
>           NULL,
> // Gateway.
>           NULL,
> // Log host.
>           {NULL},
> // Name server(s).
>     {NULL}
> // NTP server(s)
> At 03:49 PM 9/30/2004, Chris Johns wrote:
>> Steve Holle wrote:
>>> I'm trying to get BOOTP running, and when I enable it I get the
>>> following :
>>> RTEMS: BOOTP call failed -- error 105
>>> Where would I find out what error 105 is?
>> To find I do:
>>  $ cd rtems/cpukit
>>  $ grep -r "BOOTP call failed" *
>>  libnetworking/nfs/bootp_subr.c: panic("BOOTP call failed -- error
>> %d", error);
>>> Any idea what's causing it?
>> Then looking at the code I see it is an error code from the function
>> 'bootpc_call'. Another grep shows this function is in the same file,
>> and looks like it is the result of calls to socket type functions.
>> A look in errno.h gives:
>>  #define ENOBUFS 105     /* No buffer space available */
>> I see 'bootp_call' returns this value if no mbufs are available.
>> It your networking code ok ?
>>  Chris Johns
> Steve Holle
> Link Communications, Inc.
> 1035 Cerise Rd.
> Billings, MT  59101
> sholle at link-comm.com
