timer in ISR
sebastian ssmoller
sebastian.ssmoller at gmx.net
Sat Oct 2 15:27:39 UTC 2004
hi,
i try to use rtems_timer_fire_after() in a CAN Bus ISR. unfortunately this
doesnt seem to work.
i set the timer to 1000 where in non-isr code this
is a rather long period while using this code in the isr the timer service
routine seems to be executed immediately ...
so should it be generally possible to use rtems_timer_fire_after() in isr
code ?
if not, what about accessing the hardware timers directly (without rtems) -
could this be possible in an isr ?
any other ideas ? - (i need the timer to impl. somethink like a "sync
point" so that some part of the CAN bus isr is not executed til some time
has passed)
thx
regards,
seb
hardware
cpu : m68k
bsp : gen68360_040
