Reset a partition and region
Rolf Schroedter
Rolf.Schroedter at dlr.de
Mon Oct 11 11:59:20 UTC 2004
During the RTEMS school in Munich (thanks to Joel for his wunderful
presentation) we have discussed the following (real) application:
TASK-A allocates buffers/segments from a partition/region, fills the
memory with data and send messages (address,size) to a message queue.
TASK-B reads the messages queue and returns buffers/segments to the
partition/region.
For an application reset all data should be cleared.
The message queue can be cleared with message_queue_flush(),
but unfortunately the partition/region cannot be cleared so easily.
They even cannot be deleted and recreated, as long there are
buffers/segments allocated.
All that can be done now is to manually read out the message queue
and return all buffers/segments.
It would really be a big simplification to have the possibility
to reset (clear) partitions and regions:
rtems_region_reset( rtems_id id );
rtems_partition_reset( rtems_id id );
Rolf.
Rolf Schroedter
German Aerospace Center
Institute of Planetary Research
