I have Bochs Working enough to boot floppy!!
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Oct 13 15:03:53 UTC 2004
Hi All,
I have a Bochs configuration file that works enough to run the 4.5.0
grub floppy image.  I just ran it as "bochs -f b -q".
Anyone have an idea what CPU model is being simulated by default
and which other variants can be tested using different Bochs options?
How about simulating a hard disk?  Anyone done that with RTEMS?
Erwin.. did you get the TCP/IP stack working?
I would really like to get to the point where this is an easy
way to test nearly all of RTEMS.
Erwin.. then maybe someone can do the same for PearPC. :)
Here is the configuration file:
onfig_interface: textconfig
display_library: x
megs: 8
romimage: file=/usr/share/bochs/BIOS-bochs-latest, address=0xf0000
vgaromimage: /usr/share/bochs/VGABIOS-elpin-2.40
boot: floppy
floppya: 1_44=/home/joel/bochs/grub144 , status=inserted
# no floppyb
ata0: enabled=1, ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
ata1: enabled=0
ata2: enabled=0
ata3: enabled=0
parport1: enabled=1, file=""
com1: enabled=1, dev=""
usb1: enabled=1, ioaddr=0xff80, irq=10
# no sb16
floppy_bootsig_check: disabled=0
vga_update_interval: 30000
keyboard_serial_delay: 20000
keyboard_paste_delay: 100000
floppy_command_delay: 50000
ips: 500000
text_snapshot_check: 0
mouse: enabled=0
private_colormap: enabled=0
i440fxsupport: enabled=0
clock: sync=none, time0=local
# no ne2k
newharddrivesupport: enabled=1
# no loader
log: -
logprefix: %t%e%d
debugger_log: -
panic: action=fatal
error: action=report
info: action=report
debug: action=ignore
pass: action=fatal
keyboard_mapping: enabled=0, map=
keyboard_type: mf
user_shortcut: keys=none
# no cmosimage
