Eclipse
Mark Dean M.Dean at sstl.co.uk
Thu Oct 14 08:30:07 UTC 2004
Hi all,
   Currently we're trying to change the way we work and I'm looking at either
- Windows + Exceed + Eclipse to a Linux box
or
- Windows + CygWin + Eclipse
or
- some random combination of the above :-)
   I'll let you know how it goes and if I get anything running I'll Post & Wiki it.
   cheers,
   Mark.
P.S. I'd also like to say thanks to Joel and Thomas for last week's RTEMS course in Munich.
-----Original Message-----
[mailto:joel.sherrill at OARcorp.com]
Sent: 13 October 2004 22:39
To: Kit Plummer
Cc: rtems-users at rtems.com
Subject: Re: Eclipse
Kit Plummer wrote:
> Ok, curiosity killed the cat.  What OS are you using that you can't run
> Eclipse natively?  RTEMS?  Or, are you just remote?
I am on a Windows box running TightVNC to access a Linux box.  I didn't
even get to using the RTEMS cross toolset.  It did manage to checkout
something from CVS and then when I clicked on a C file in that checked
out project, the VNC client died.
--joel
> Kit
> On Oct 13, 2004, at 12:18 PM, Joel Sherrill <joel at OARcorp.com> wrote:
>> Steve Holle wrote:
>>> Thanks for the info.  I don't have any questions for the moment but I
>>> will keep your email for when we start bring up Eclipse.
>> I would appreciate it very much if one of you could add
>> a Wiki entry for Eclipse and RTEMS info.
>> I tried Eclipse 3.0.1 today only to learn that it crashes VNC.
>> It looks to be a known problem and hopefully is going away
>> in the next release series.  I spend most of my time on a
>> VNC connection so it isn't ready for me yet. :(
>> --joel
>>> Thanks.
>>> At 11:09 AM 10/13/2004, Mark VanderVoord wrote:
>>>> Steve:
>>>> I have a configuration similar to what you describe,
>>>> but not exact.  I am using Eclipse with CDT as a cross
>>>> development platform for RTEMS.  In the past I had
>>>> (briefly) tried to use MinGW as my cross-compilation
>>>> tools.  I was not very successful with that.  Instead,
>>>> I am running cygwin to run the cross platform tools.
>>>> Very little is required to change the behavior of CDT
>>>> to support cross development.  You will need to
>>>> retarget the make and gdb calls to point at your
>>>> platform-specific tools, instead of the default ones
>>>> that are packaged with CDT.  This can be done through
>>>> the "make targets" pane and the debug drop down menu.
>>>> I am currently running Eclipse 2.1 and CDT 1.2.  There
>>>> are much newer versions of each, but I haven't had
>>>> time to update them recently.
>>>> Because Eclipse references any standard GDB
>>>> implementation with the machine interface, it can be
>>>> used in place of Insight to directly debug your code.
>>>> I have had varying luck on this, as the machine
>>>> interface seems to be lacking or buggy, depending on
>>>> which cross compiler tool I am working with.  Other
>>>> targets have worked beautifully.  At worst, it is easy
>>>> to configure Eclipse to launch Insight when needed.
>>>> Anything else you would like to know about this?
>>>> Mark S VanderVoord
>>>> Self-Guided Systems, LLC
>>>> --- Steve Holle <sholle at link-comm.com> wrote:
>>>> > I'm interested in info on using Eclipse with the CDT
>>>> > plugin as a
>>>> > cross-development platform on a W2K system using
>>>> > MinGW and GDB connected to
>>>> > the Eclipse debugger.  This seems like an intriguing
>>>> > configuration.  Just
>>>> > doing research at the moment.
>>>> > Steve Holle
>>>> > Link Communications, Inc.
>>>> > 1035 Cerise Rd.
>>>> > Billings, MT  59101
>>>> _______________________________
>>>> Do you Yahoo!?
>>>> Express yourself with Y! Messenger! Free. Download now.
>>>> http://messenger.yahoo.com
>>> Steve Holle
>>> 1035 Cerise Rd.
>>> Billings, MT  59101
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel at OARcorp.com                 On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
