RTEMS-mvme5500 BSP available
Feng, Shuchen
feng at bnl.gov
Thu Oct 14 19:52:55 UTC 2004
Hi all,
Finally, we got official approval from DOE to release the
RTEMS-mvme5500 BSP under EPICS open source. Before the BSP
is officially merged to the RTEMS release, the source code
can be downloaded from :
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software
Joel Sherrill wrote :
> Feng, Shuchen wrote:
>> May I know what is the requirement of the official submission ?
> Source code is the first and most obvious one.
> The second is permission. This involves you transmitting the
> code to the RTEMS Project via email, ftp to incoming, etc..
> The source code must have appropriate licensing and
> redistribution requirements. Given that you are submitting
> a BSP, the license should be standard RTEMS -- GPL with
> exception.
As per discussion off-line regarding the license, Joel had
accepted the EPICS license consdering the fact that it is
compatible with the RTEMS one. Many thanks to Joel's
consideration.
> The third is practical. I don't want to merge any code
> before you think it is ready.
I think it is ready. Presently, there is no known bug
based on our application. I think I even fixed the URL
wrapped problem from the original message below.
Looking forwards to feedback.
Regards,
Kate
> -----Original Message-----
> From: Joel Sherrill <joel at OARcorp.com>
> To: Till Straumann
> Cc: Feng, Shuchen; 'rtems-users at rtems.com'; 'tech-talk at aps.anl.gov'
> Sent: 9/20/2004 5:42 PM
> Subject: Re: RTEMS-mvme5500 BSP available
>>>Hello,
>>>The source code for the RTEMS-mvme5500 BSP is
>>>available for evaluation upon request to feng1 at bnl.gov
>>>before it's in the RTEMS source tree.
>>>Other related document can be found at
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/Defa
> ult.
>>I get an infamous Http/404 (page not found) error when trying
>>to access this page :-(
> The URL wrapped .. add "htm" after the "." at the end.
> THis looks like a pre-submission test snapshot again. :(
> Still waiting.. hoping... :)
> --joel
>>-- T.
>>>htm
>>>Regards,
>>>Kate
joel at OARcorp.com On-Line Applications Research
