Memory leak after C++ exception
Till Straumann
strauman at slac.stanford.edu
Thu Oct 14 21:21:45 UTC 2004
I looked into the RTEMS gthread support implementation
and I didn't like too much what I saw:
a) it uses task variables :(
b) it leaks memory, indeed. The destructor is never called
and the memory allocated for the task variable doesn't seem
to be released either (probably not a big problem).
The implementation with task variables is not satisfactory and
hard to understand. Also, a task variable doesn't behave exactly
like a gthread key. It isn't created along with a task and doesn't
die with it (--> if you call gxx_key_delete, there may still
be threads around using the task variable related to the key).
IMO, it would be desirable to have a few fields in the libc reent
structure for supporting this kind of things (including 'privateenv'
and 'rpc context' pointers).
d) BTW: The gthread_once() implementation could also be improved:
It disables task preemption around the callback function
which doesn't seem necessary.
===> I propose an overhaul of cpukit/libcsupport/src/gxx_wrappers.c
-- Till
(Didn't file a PR because I don't consider the attached [untested!]
patch a permanent solution)
Valery Pykhtin wrote:
> Hi all,
> I detected memory leak dealing with C++ exceptions. The sympthoms are
> following:
> 1. start new task
> 2. do smth
> 3. throw
> 4. catch
> 5. task selfdeletes
> 6. Memory leak ! The chunk of memory allocated from
> gcc-3.2.2\libstdc++-v3\libsupc++\eh_globals.cc, line 107 is not freed.
> the code around that place
> g = (__cxa_eh_globals *) __gthread_getspecific (globals_key);
> if (! g)
> if ((g = (__cxa_eh_globals *)
> std::malloc (sizeof (__cxa_eh_globals))) == 0 // **** <=== that is !!!
> || __gthread_setspecific (globals_key, (void *) g) != 0)
> std::terminate ();
> g->caughtExceptions = 0;
> g->uncaughtExceptions = 0;
> My platform bsp is pc586, rtems ver is 4.6.0pre5. I can send the test I
> used to detect the leak.
> What can I do now ?
> Best regards,
> Valery
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20041014/12b34c3d/attachment.ksh>
