Extracting Dosfs
Daniel Gustafsson daniel.gustafsson at space.se
Fri Oct 15 06:48:17 UTC 2004
Thanks for the answer...
What are the constraints of the FS (max partitions etc.). I want to run on a
system with approx eigth partitons with 1GB each.
I am going to try to extract dosfs for Rtems for a couple of days. If I
understand correctly the file system structure are as follows:
   USER
 LIBSUPPORT
   DOSFS (MSDOS*PREFIX)
   DOSFS (FAT*PREFIX)
   DRIVER
SPECIFIC HARDWARE
If I am totally wrong, please correct me.
Regards
Daniel
>-----Original Message-----
>From: Bogdan Vacaliuc [mailto:bvacaliuc at ngit.com]
>Sent: Friday, October 15, 2004 3:02 AM
>To: 'Daniel Gustafsson'
>Cc: rtems-users at rtems.com
>Subject: RE: Extracting Dosfs
>Ugh.
>> inside an RTEMS environment.  The code is stand-alone and compiles
>> readily under GNU/Linux, Cygwin, etc.
>I lied when I said it compiles readily.  Two years ago was
>when I started with it...  Funny, I remember whipping it together and
>demonstrating its functionality quite quickly.  Sigh.  I guess
>it will just take a little more time and coddling that I expected.
>-bogdan
>On Thursday, October 14, 2004 10:52 AM, Bogdan Vacaliuc wrote:
>> Hi Daniel,
>> You may want to follow the ongoing "Formatting DOSFS volume" thread
>> in RTEMS:
>> http://www.rtems.com/ml/rtems-users/2004/october/msg00086.html
>> The RDCF2 code (http://alumnus.caltech.edu/~pje/rdcf2.txt) may be
>> just what you are looking for if you are not interested in running
>> Best Regards,
>> -bogdan
>> On Thursday, October 14, 2004 9:37 AM, Victor V. Vengerov wrote:
>>> Daniel,
>>> Have in mind that libblock depends on some RTEMS synchnorisation
>>> mechanisms, and run the thread writing blocks to the disk. Also,
>>> ms-dos file system and libblock has been designed with mulithreading
>>> in mind, which may be overhead for you. More free open-source MS-DOS
>>> implementations are exists (I remember freedos name,
>although I'm not
>>> sure) - may be it is better appropriate for you.
>>> I don't know what are you going to implement, but it will be
>>> definitievly simpler to link your application with RTEMS,
>considering
>>> it as a library providing some services, particularly DOS file
>>> system. Nothing prevent you to implement single-threaded application
>>> in RTEMS - just run it as a initialisation task.
>>> Victor
>>> Daniel Gustafsson wrote:
>>>> I am interested in extracting Dosfs in Rtems 4.6.1 to a separate
>>>> module that shall work stand-alone with a commandpromt. The module
>>>> should use a block based ram driver like a simulated disk. Before I
>>>> start I would like to ask if somebody has done the same thing or
>>>> knows any good approaches? The main questions I would like to have
>>>> an answer to is the following:
>>>> 1. What does the file structure of dosfs look like? Which files are
>>>> necessary for a stand-alone module? Which files are
>connected to the
>>>> different layers (driver, upper interface etc.) of the file system?
>>>> 2. Where should I start? Any tips is greatly accepted?
>>>> 3. Can somebody tell me about any constraints or limitations of the
>>>> fs (max partition size etc.)?
>>>> 4. Does anyone know the footprint of dosfs in RAM during runtime?
>>>> Best Regards
>>>> Daniel Gustavsson
