"Issue" in termiosinitialize.c
Till Straumann strauman at slac.stanford.edu
Fri Oct 15 21:23:15 UTC 2004
AFAIK, there is a lot of code that assumes
uninitialized data (not malloc()ed) is zero
at startup.
It is definitely a bug not to zero bss, of course.
-- Till
Smith, Gene wrote:
> This may or may not arise to the level of a bug. The problem was that I
> had forgotten to zero out bss section at startup. The function
> cpukit/libcsupport/src/termiosinitialze.c
> defines a global variable that, in the same file, is assumed to be zero
> at startup. Since uninitialized data was not zero'd the termios init
> failed for me.
> If the variable rtems_termios_ttyMutex had been explicitly set to zero
> when defined it would not have mattered if bss was zero'd.
> Bug or not a bug?
> Diff attached.
> -gene
> --- termiosinitialize.c	2003-09-04 14:46:58.000000000 -0400
> +++ termiosinitialize-fixed.c	2004-10-15 16:49:56.000000000 -0400
> @@ -31,7 +31,7 @@
>  struct rtems_termios_tty *rtems_termios_ttyHead;
>  struct rtems_termios_tty *rtems_termios_ttyTail;
> -rtems_id rtems_termios_ttyMutex;
> +rtems_id rtems_termios_ttyMutex = 0; /* assumed to be zero at startup */
>  void
>  rtems_termios_initialize (void)
