"Issue" in termiosinitialize.c
Eric Valette eric.valette at free.fr
Sat Oct 16 12:57:01 UTC 2004
Joel Sherrill <joel at OARcorp.com> wrote:
> I believe the C language standard calls for the
> invoking environment to clear the BSS.
That's rather clear : of course, non initialized variable are located
into the BSS area but for many compiler's including (if I remember
correctly) some gcc incarnation, a base type variable explicitely
initialized to zero goes also ends up located into the BSS area... In
that case, if you do not zero the BSS, you're dead...
    __
   /  `                   	Eric Valette
  /--   __  o _.          	6 rue Paul Le Flem
(___, / (_(_(__         	35740 Pace
Tel: +33 (0)2 99 85 26 76	Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
