Wiki Accounts
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Oct 19 11:30:12 UTC 2004
Angelo Fraietta wrote:
> Can someone give me very simple instructions on how to sign in to Wiki?
> I must be doing something wrong because I cannot get in
Weird.  I logged in as you. :(
I added a page as AngeloFraietta.  You should be able to just login.
Do you have any cookies left from the site?
--joel
>>> I am unable to log in at all
>>> I get the following error
>>> lib/WikiUserNew.php:2009: Warning[512]: Unable to connect to IMAP
>>> server localhost:143/imap/notls
>> Are you trying to get a password?  Don't bother, it doesn't work.
>>>> Ralf Corsepius wrote:
>>>>> On Tue, 2004-09-28 at 00:53, Aaron J. Grier wrote:
>>>>>> On Mon, Sep 27, 2004 at 06:15:55PM +0200, Ralf Corsepius wrote:
>>>>>>> On Mon, 2004-09-27 at 17:30, Joel Sherrill  wrote:
>>>>>>>> I was wrong.  You can add yourself a personal page/account.
>>>>>>> How? Detailed instructions, please.
>>>>>>> ATM, to me, this Wiki appears to be plain simple non-functional.
>>>>>> * go to http://www.rtems.com/phpwiki/ .
>>>>>> * in the bottom right corner next to the "sign in as" button, put
>>>>>> your
>>>>>>  desired username and click the "sign in as" button.
>>>>>> * the main page will reload again, this time it will say
>>>>>> "authenticated
>>>>>>  as UserName" at the bottom.  there will be a question mark next
>>>>>> to the
>>>>>>  username.  click on the question mark and fill out the profile page.
>>>>> Thanks, however, this is exactly what I did and what only seems to be
>>>>> working at random for me.
>>>>> I have filed screenshots of 2 failing attempts to RTEMS bug database.
>>>>> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=685
>>>>> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=684
>>>> I think the trick is to create your personal page as soon as you log
>>>> in.
>>>> If you leave without one, it appears to be hard to get back in.
>>>> What I am doing is "Finding" your PersonalPage.  It doesn't exist, so
>>>> I create it with some dummy modification, then check that I can
>>>> login as you and it has always worked (so far).
>>>> What is really happening I don't know.
>>>>>> * once you are logged in you can change your password by clicking on
>>>>>>  "Preferences" at the top of any page.
>>>>> When I manage to "sign in" (I can sign-in using an account which,
>>>>> AFAICT
>>>>> Joel has created manually) PhpWiki replies:
>>>>> Password cannot be changed. No changes.
>>>> There really is no password system enabled in our installation.
>>>> PhpWiki appears to support various password schemes but so far I
>>>> can't make any of them work. When I do figure it out, I will go
>>>> through and assign all
>>>> users a password and email it to you.
>>>>> Ralf
