stdc++ (cout) problem with RTEMS on Sparc emulator
Fri Oct 22 00:39:28 UTC 2004
Courtney B. Duncan wrote:
> The questions are:  Am I on the right track in tracking down this
> problem?  Does C++ cout work for anybody under RTEMS?  Isn't there a
> printf() based cout implementation that ought to work in this situation?
I use C++, libstdc++.a, the STL on a Coldfire processor with no problems.
Is the correct library being linked ?
If your target (sparc) tools are being built as multilib then check if
the library for your specific variant is being built. If it does not get
built, the compiler will link the default library and not warn you. This
can result is strange problems due to different instructions.
If the correct library is being linked, the other area of potential
trouble is the atomic lock type operations. You will find this code in a
file called 'atomicity.h' under the:
  $prefix/lib/gcc/<target stuff>/include/c++/<target>/bits
directory.
  Chris Johns
