Help with Bochs Needed
Erwin Rol mailinglists at erwinrol.com
Mon Oct 25 17:24:30 UTC 2004
try enabling the Bochs GDB support and debug with GDB. I time i had the
same problem , and than it went away, the thing is i am not sure why :-)
It seemed to hang endlessly in a timer calibration routines, i wasn't
crashed, it just didn't get forward. I bet it is the same thing.
Ok not really helpful but thats all i know at the moment :-)
- Erwin
On Mon, 2004-10-25 at 12:07 -0500, Richardson, Anthony wrote:
> Erwin Rol wrote:
> > I saw that problem too, it seems to hang in the timer calibration
> > routines. Could you try if the following line in yer bochs config file
> > helps.
> > clock: sync=none, time0=local
> > - Erwin
> It didn't help.  The hello example does not produce any output.
> The hello example on the grub floppy from the contrib directory
> works with or without the above line, but the one that I build
> does not.
> Thanks,
> Tony
