Makefiles
James Yates j.yates at quartzuk.com
Tue Oct 26 10:47:36 UTC 2004
I have tried this and i get a much bigger executeable, but that's to be
expected, although it is too big for me run through my GDB stub. I
really want to find a solution whereby I can specify a list of sources
that are not optimised as well as a list of sources that are optimised.
I have 2 files out of 30 that I need optimisation turned off for, the
rest I really want optimised. The template Makefile.leaf only seems to
cope with one set of CFLAGS for all c files. This is quite an unusual
problem, but one I am eager to solve. Does anyone have any ideas? I know
a bit about makefiles, but I am no expert.
		James
> -----Original Message-----
> From: Till Straumann [mailto:strauman at slac.stanford.edu]
> Sent: 25 October 2004 17:35
> To: Jay Monkman
> Cc: James Yates; RTEMS Users
> Subject: Re: Makefiles
> Jay Monkman wrote:
> > On Mon, Oct 25, 2004 at 04:42:29PM +0100, James Yates wrote:
> >>This is for RTEMS 4.6.0.
> >>   This would be a nice thing to have on a permanent basis.
> Inside my
> >>makefile I have a CFLAGS+=  line.
> (I was assuming you are using the template 'Makefile.leaf').
> >> When I added -O0 to it, my rtems app
> >>seemed to fail to work. I didn't bother investigating this
> perhaps I
> >>should have.
> Yes, you should have. I tested 'CFLAGS+= -O0' with one of my
> applications and it works fine. Could be that disabling
> optimization triggers a bug in your code?
> >>Can I then change CFLAGS+=  to CFLAGS =  and use completely
> different
> >>flags in building the app to when I built RTEMS.
> Yes, but you are discouraged to do so [unless you really know
> what you are doing]. The BSP might know of vital flags which
> must not be omitted.
> T.
> > Are you using something like the template Makefile.leaf?
> > If so, you can modify/overwrite CFLAGS after the lines:
> >    include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> >    include $(RTEMS_CUSTOM)
> >    include $(RTEMS_ROOT)/make/leaf.cfg
