Strange filesystem mounting behavior: That was a stupid question
Etienne Fortin etienne.fortin at sensio.tv
Wed Oct 6 13:34:00 UTC 2004
Hi Thomas,
Yes, that was the problem. Now the "next" problem in the chain is that
diskdevs.c:get_disk_entry() crash since my "device" seem to not have
been registered as a block device. I'm in the process of finding how
this registration should be done: confdefs.h macros or function call of
some sort.
Thanks for your help,
Etienne Fortin
-----Message d'origine-----
De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
Envoyé : 5 octobre, 2004 17:03
À : Etienne Fortin
Cc : rtems-users at rtems.com
Objet : Re: Strange filesystem mounting behavior: That was a stupid
question
Etienne,
did you configure your application to use the "real" IMFS? If
you don't select it explicitly, only the "miniIMFS" is use,
which needs fewer code and data memory, but only supports the
creation of device nodes.
You must have select
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
I hope this helps!
By the way: maybe you should not be SO pessimistic:
"As we can expect from early tests, it doesn't work :)"
It seems you have a caring computer, which tries to fulfill your
expectations ;->
wkr,
Thomas.
> Sorry guys, my last mail was stupid. I didn't realize that "loc" is
> not about the DOSFS file system but about the IMFS filesystem which is
> the base filesystem. It doesn't explain why it doesn't have any mount
> handler, but I'll find out.
> Anyway, thanks for your time :)
> Etienne Fortin
> Sensio
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
