Eclipse
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Oct 13 19:18:47 UTC 2004
Steve Holle wrote:
> Thanks for the info.  I don't have any questions for the moment but I
> will keep your email for when we start bring up Eclipse.
I would appreciate it very much if one of you could add
a Wiki entry for Eclipse and RTEMS info.
I tried Eclipse 3.0.1 today only to learn that it crashes VNC.
It looks to be a known problem and hopefully is going away
in the next release series.  I spend most of my time on a
VNC connection so it isn't ready for me yet. :(
--joel
> Thanks.
> At 11:09 AM 10/13/2004, Mark VanderVoord wrote:
>> Steve:
>> I have a configuration similar to what you describe,
>> but not exact.  I am using Eclipse with CDT as a cross
>> development platform for RTEMS.  In the past I had
>> (briefly) tried to use MinGW as my cross-compilation
>> tools.  I was not very successful with that.  Instead,
>> I am running cygwin to run the cross platform tools.
>> Very little is required to change the behavior of CDT
>> to support cross development.  You will need to
>> retarget the make and gdb calls to point at your
>> platform-specific tools, instead of the default ones
>> that are packaged with CDT.  This can be done through
>> the "make targets" pane and the debug drop down menu.
>> I am currently running Eclipse 2.1 and CDT 1.2.  There
>> are much newer versions of each, but I haven't had
>> time to update them recently.
>> Because Eclipse references any standard GDB
>> implementation with the machine interface, it can be
>> used in place of Insight to directly debug your code.
>> I have had varying luck on this, as the machine
>> interface seems to be lacking or buggy, depending on
>> which cross compiler tool I am working with.  Other
>> targets have worked beautifully.  At worst, it is easy
>> to configure Eclipse to launch Insight when needed.
>> Anything else you would like to know about this?
>> Mark S VanderVoord
>> Self-Guided Systems, LLC
>> --- Steve Holle <sholle at link-comm.com> wrote:
>> > I'm interested in info on using Eclipse with the CDT
>> > plugin as a
>> > cross-development platform on a W2K system using
>> > MinGW and GDB connected to
>> > the Eclipse debugger.  This seems like an intriguing
>> > configuration.  Just
>> > doing research at the moment.
>> > Steve Holle
>> > Link Communications, Inc.
>> > 1035 Cerise Rd.
>> > Billings, MT  59101
>> _______________________________
>> Do you Yahoo!?
>> Express yourself with Y! Messenger! Free. Download now.
>> http://messenger.yahoo.com
> Steve Holle
> 1035 Cerise Rd.
> Billings, MT  59101
