Eclipse
Kit Plummer
christopher_plummer at raytheon.com
Wed Oct 13 21:24:40 UTC 2004
Ok, curiosity killed the cat. What OS are you using that you can't run
Eclipse natively? RTEMS? Or, are you just remote?
Kit
On Oct 13, 2004, at 12:18 PM, Joel Sherrill <joel at OARcorp.com> wrote:
> Steve Holle wrote:
>> Thanks for the info. I don't have any questions for the moment but I
>> will keep your email for when we start bring up Eclipse.
> I would appreciate it very much if one of you could add
> a Wiki entry for Eclipse and RTEMS info.
> I tried Eclipse 3.0.1 today only to learn that it crashes VNC.
> It looks to be a known problem and hopefully is going away
> in the next release series. I spend most of my time on a
> VNC connection so it isn't ready for me yet. :(
> --joel
>> Thanks.
>> At 11:09 AM 10/13/2004, Mark VanderVoord wrote:
>>> Steve:
>>> I have a configuration similar to what you describe,
>>> but not exact. I am using Eclipse with CDT as a cross
>>> development platform for RTEMS. In the past I had
>>> (briefly) tried to use MinGW as my cross-compilation
>>> tools. I was not very successful with that. Instead,
>>> I am running cygwin to run the cross platform tools.
>>> Very little is required to change the behavior of CDT
>>> to support cross development. You will need to
>>> retarget the make and gdb calls to point at your
>>> platform-specific tools, instead of the default ones
>>> that are packaged with CDT. This can be done through
>>> the "make targets" pane and the debug drop down menu.
>>> I am currently running Eclipse 2.1 and CDT 1.2. There
>>> are much newer versions of each, but I haven't had
>>> time to update them recently.
>>> Because Eclipse references any standard GDB
>>> implementation with the machine interface, it can be
>>> used in place of Insight to directly debug your code.
>>> I have had varying luck on this, as the machine
>>> interface seems to be lacking or buggy, depending on
>>> which cross compiler tool I am working with. Other
>>> targets have worked beautifully. At worst, it is easy
>>> to configure Eclipse to launch Insight when needed.
>>> Anything else you would like to know about this?
>>> Mark S VanderVoord
>>> Self-Guided Systems, LLC
>>> --- Steve Holle <sholle at link-comm.com> wrote:
>>> > I'm interested in info on using Eclipse with the CDT
>>> > plugin as a
>>> > cross-development platform on a W2K system using
>>> > MinGW and GDB connected to
>>> > the Eclipse debugger. This seems like an intriguing
>>> > configuration. Just
>>> > doing research at the moment.
>>> > Steve Holle
>>> > Link Communications, Inc.
>>> > 1035 Cerise Rd.
>>> > Billings, MT 59101
>>> _______________________________
>>> Do you Yahoo!?
>>> Express yourself with Y! Messenger! Free. Download now.
>>> http://messenger.yahoo.com
>> Steve Holle
>> 1035 Cerise Rd.
>> Billings, MT 59101
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
