Can we run RTEMS under AT91SAM7S256?
Jay Monkman jtm-list-rtems at smoothsmoothie.com
Thu Oct 21 03:51:56 UTC 2004
On Thu, Oct 21, 2004 at 05:28:49AM +0200, Ralf Corsepius wrote:
> > I'm sure those could be reduced some with effort.
> Definitely.
> Did you try to compile RTEMS w/ -Os?
Doesn't make a difference. I'm using -O3 already. In the ARM stuff, I
know the processor stacks could be reduced, and there's a 4K buffer
used for an incompletely implemented data abort handler and it should
be removed altogether.
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20041020/3e582f5d/attachment-0001.bin>
