Help with Bochs Needed
Richardson, Anthony
ar63 at evansville.edu
Mon Oct 25 17:07:11 UTC 2004
Erwin Rol wrote:
> I saw that problem too, it seems to hang in the timer calibration
> routines. Could you try if the following line in yer bochs config file
> helps.
> clock: sync=none, time0=local
> - Erwin
It didn't help. The hello example does not produce any output.
The hello example on the grub floppy from the contrib directory
works with or without the above line, but the one that I build
does not.
Thanks,
Tony
> On Mon, 2004-10-25 at 07:15 -0500, Richardson, Anthony wrote:
> > I can't seem to get applications running under
> > Bochs. I'm trying to get the hello example running.
> > I'm using RTEMS 4.6.2 under cygwin. I configure
> > using the i386-rtems target and the pc386 BSP.
> > Everything seems to compile and build without any
> > problems.
> > I copy the hello.exe to my hard disk image and start
> > Bochs. At the grub prompt I type:
> > root (hd0,0)
> > kernel /hello.exe
> > and grub responds
> > [Multiboot-elf, <0x100000:0x18fc4:0x2768>, shtab=0x11c140,
> > entry=0x10000c]
> > which seems to indicate that grub recognizes it as a proper kernel
> > anyway.
> > I then type (at the grub prompt):
> > boot
> > The bochs screen goes blank, but then nothing is displayed.
> > I've tried some of the other examples with similar results.
> > Am I doing something incorrectly or am I overlooking something?
> > Any help is greatly appreciated.
> > Tony Richardson
