Help with Bochs Needed
Richardson, Anthony ar63 at evansville.edu
Mon Oct 25 17:58:15 UTC 2004
Erwin Rol wrote:
> try enabling the Bochs GDB support and debug with GDB. I time
> i had the
> same problem , and than it went away, the thing is i am not
> sure why :-)
> It seemed to hang endlessly in a timer calibration routines, i wasn't
> crashed, it just didn't get forward. I bet it is the same thing.
> Ok not really helpful but thats all i know at the moment :-)
> - Erwin
OK, I'll try that to see if I can figure out what's going on.  Here's
some additional info though.  When I use the grub kernel command to
load hello.exe from the grub disk in the contrib directory (the one that
works), I get the response:
[NetBSD-a.out, loadaddr=0x100000, text=0xf970, C, data=0xb20, bss=0xd28,
entry=0x100000]
when I load the hello.exe that I get from my RTEMS build (the one that
doesn't work), I get:
[Multiboot-elf, <0x100000:0x18fc4:0x2768>, shtab=0x11c140,
entry=0x10000c]
so the executable files are of different type.  Did I miss a configure
option
or something that allows me to create a.out files instead of
Multiboot-elf?
Tony
> On Mon, 2004-10-25 at 12:07 -0500, Richardson, Anthony wrote:
> > Erwin Rol wrote:
> > > I saw that problem too, it seems to hang in the timer calibration
> > > routines. Could you try if the following line in yer
> bochs config file
> > > helps.
> > > clock: sync=none, time0=local
> > > - Erwin
> > It didn't help.  The hello example does not produce any output.
> > The hello example on the grub floppy from the contrib directory
> > works with or without the above line, but the one that I build
> > does not.
> > Thanks,
> > Tony
