Development Plan Proposal for Unifying Interrupt and PCI APIs
Eric Valette eric.valette at free.fr
Tue Oct 26 13:01:36 UTC 2004
Joel Sherrill <joel at OARcorp.com> wrote:
> So I guess I think the Linux design is right.  It gives a clean
> division between CPU model code and BSP code.  It is easy to explain
> and really gives the BSP some freedom.
Sure but the number of instruction per IRQ is about 20 times the really
minimal set needed, simple IO instruction are also replaced by function
calls and the memory requirement may even be worse. It is true that as
if this is not a problem for libchip why start to worry about IRQs.
I, _personnaly_, would not like to pay this price for an RTOS where 90%
of cpu time can be spent handling irqs. Now if maintenance or teaching
is really more important than performance, I must admit I only have to
shut up.
BTW, back to technical, allthough flexible, the linux model makes it
nearly impossible to define IRQ masking set as the function to
acknowledge and mask the current IRQ :
	1) Mask only the current IRQ,
	2) does not return the old mask, and that it cannot be restored
afterwards...
So it is flexible but not sufficient for a RTOS and people are already
complaining about that and fixing it is not trivial as no patch exist yet.
> RTEMS has very clear APIs for the most part.  The structure of BSPs is
> well documented and can be explained.  Then you try to explain the PCI
> or interrupt APIs and find out that everything is in terms of "if on
> this port, then...".  That is fundamentally bad because it undermines
> the ability to clearly teach and understand RTEMS. You can have
> expertise on RTEMS one CPU family and be totally unfamiliar with
> another.  Not just at the hardware level but at the software structure
> and "what does this call do?" level.
VxWorks user are accustommed to this allthough it is still the n°1
commercial RTOS... But yes unifying API is a good thing. I worry more
about how efficiently it will be done. Do not forget to precisely
benchmark actual performance and compare with what you come up with when
you will be readdy.
I think the goal to be able to distribute only a set of .o file and
enable to write a BSP makes any trick like including ASM, redefining
generic IRQ names really challenging. Don't you think? It will not be
function calls but indirect function calls then...
With the BSP model, and removing interrupt connecting from non BSP parts
this becomes a void problem.
-- eric
