ppc405 dma - vm - cache question
gregory.menke at gsfc.nasa.gov
Wed Oct 27 18:11:43 UTC 2004
Feng, Shuchen writes:
> >The hadrware snoop should be some mechanism provided by your ethernet
> >controller if available. For example, it is programmable by registers
> >if desired for my 10/100 MHZ ethernet of the mvme5500 BSP.
> >Did anyone implement software snoop to ensure cache coherence in RTEMS ?
> >I thought the software snoop would impose overhead that one might as
> >well
> >map the accessed memory to be non-cachable (e.g. implemented in the
> >RTEMS motorola_shared bsp's). Maybe someone can verify this for me.
> I do not know how well ethernet driver perform with non-cacheable memory.
Please ask this question more specifically.
> >It seems to me that PPC405 does not use the RTEMS motorola_shared bsp,
> >and your firmware maps the accessed memory to be cachable.
> I really do not have the datasheet for the RTEMS motorola_shared BSP.
> It could be that the firmware of thoses supported board already
> had the hardware snoop turned on. It would be better if you can
> find out how to turn the hardware snoop on for your board.
The motorola_shared bsp configures the system ram such that it can be
the dma target or dma source, with a bus-mastering board on the
backplane. No additional hardware-level configuration is necessary
unless you want the hardware to do something extra. All PCI memory
space is configured as non-cached, which I imagine is pretty much
standard these days. Nobody is putting system ram on the pci
backplane.
Gregm
