Help: RTEMS Threads, Preemptation and Time slicing...
Paul Whitfield
paulw at omnitronics.com.au
Thu Oct 28 02:19:19 UTC 2004
Ian Caddy wrote:
> Hi Alex,
> If your threads are the same priority, pre-emption will not cause one of
> them to stop, as it will only pre-empt for HIGHER priority threads.
> In this case, you will need to configure these threads for round-robbin
> (or timeslicing) to achieve what you are asking.
The example states and is in time slice / Round robin mode.
> In saying that though, your system design should never, in practise,
> consist of tasks that are continuously running as no other task of a
> lower priority level will ever get to run in this sort of system. A
> normal system design will have tasks waiting on things from other tasks,
> or if not, sleeps that allow the task to yield to lower priority tasks.
Indeed! I personally consider systems that need round robins
to work as broken (but that is just a personal preference!).
I have a few things that you could look at:
1) Is the compiler optimizing you test loops out of existence?
2) The default values for CONFIGURE_MICROSECONDS_PER_TICK (10000)
and CONFIGURE_TICKS_PER_TIMESLICE (50) will mean that your
task will only do a round robin every 0.5 seconds, perhaps this
is too slow?
Good Luck
Paul
