rtems gdb/insight to jtag
Jay Monkman jtm-list-rtems at smoothsmoothie.com
Wed Sep 1 02:28:26 UTC 2004
On Tue, Aug 31, 2004 at 05:21:02PM -0400, Smith, Gene wrote:
> Oh, ok. I see. You actually use your own gdb and bdiGDB is just an
> adaptation layer.
Right. You connect to the debugger via ethernet. You just tell gdb the
debugger's hostname (or IP address).
> fyi, here is the price they quoted me from their US distributor, USI:
> USI07-33103 ABTR BDI2000 & bdiGDB - PPC4xx 		$2,570.00
> USI07-20301K ABTR US Power Supply & Cable Kit
> -AC/DC 5V Power Supply
> -USB to RS-232 Cable
> -Ethernet Cables (Std-YLW & Xover-GRY)			$199.00
The used to sell just the power supply for ~$60. I don't know if they
still do. $130 seems like a lot for a couple ethernet cables and
USB<->RS232 adapter.
> USI07-SPRT-1 ABTR PAP Subscription (GDB/Wind) - 1YR
> -Phone support via The PTR Group - 1YR
> -Extends software updates - 1YR to 2YRS
> -Update Notification - bdiGDB				$395.00
That's not required. It's just an extended support plan.
If you need work with other architectures, the firmware for each one
is around $1000.
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20040831/9f54c876/attachment.bin>
