cygwin build_alias issue
Scott Newell newell at cei.net
Thu Sep 2 13:11:59 UTC 2004
At 12:13 AM 9/2/2004 , Ralf Corsepius wrote:
>> maybe this:
>>   ac_optarg=`strace -o /tmp/strace.log expr "x$ac_option" :
'x[^=]*=\(.*\)'`
>> strace logfile attached.
>I don't see anything obvious.
>Anyway, that's the wrong expr call :-)
Oops.  Sorry about that.
>The interesting expr is this one, near line 624 in cpukit/configure:
> expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
>      { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
>   { (exit 1); exit 1; }; }Can you try to strace this one?
Attached.  (~24k)
newell
Program name: D:\cygwin\bin\expr.exe (1840)
App version:  1005.0, api: 0.88
DLL version:  1005.10, api: 0.116
DLL build:    2004-05-25 22:07
OS version:   Windows NT-5.0
Heap size:    402653184
Date/Time:    2004-09-02 08:06:01
  913    2022 [main] expr 1840 environ_init: 0x10010008: !D:=D:\cygwin\bin
  256    2278 [main] expr 1840 environ_init: 0x10010250: !G:=G:\Documents and Settings\Administrator\Desktop
  223    2501 [main] expr 1840 environ_init: 0x10010288: ALLUSERSPROFILE=G:\Documents and Settings\All Users
  400    2901 [main] expr 1840 environ_init: 0x100102C0: APPDATA=G:\Documents and Settings\Administrator\Application Data
  273    3174 [main] expr 1840 environ_init: 0x10010308: COMMONPROGRAMFILES=G:\Program Files\Common Files
  233    3407 [main] expr 1840 environ_init: 0x10010340: COMPUTERNAME=NEWELL
  218    3625 [main] expr 1840 environ_init: 0x10010358: COMSPEC=G:\WIN2K\system32\cmd.exe
  246    3871 [main] expr 1840 environ_init: 0x10010380: CONFIG_SHELL=/bin/bash
  194    4065 [main] expr 1840 environ_init: 0x100103A0: CVS_RSH=/bin/ssh
  220    4285 [main] expr 1840 getwinenv: can't set native for HOME= since no environ yet
  215    4500 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\home\Administrator, no-keep-rel, no-add-slash)
  121    4621 [main] expr 1840 normalize_win32_path: D:\cygwin\home\Administrator = normalize_win32_path (D:\cygwin\home\Administrator)
  125    4746 [main] expr 1840 mount_info::conv_to_posix_path: /home/Administrator = conv_to_posix_path (D:\cygwin\home\Administrator)
  316    5062 [main] expr 1840 win_env::add_cache: posix /home/Administrator
  112    5174 [main] expr 1840 win_env::add_cache: native HOME=D:\cygwin\home\Administrator
  105    5279 [main] expr 1840 posify: env var converted to HOME=/home/Administrator
  241    5520 [main] expr 1840 environ_init: 0x100103E0: HOME=/home/Administrator
  203    5723 [main] expr 1840 environ_init: 0x10010530: HOMEDRIVE=G:
  218    5941 [main] expr 1840 environ_init: 0x10010548: HOMEPATH=\
  208    6149 [main] expr 1840 environ_init: 0x10010558: HOSTNAME=newell
  200    6349 [main] expr 1840 environ_init: 0x10010570: INFOPATH=/usr/local/info:/usr/info:/usr/share/info:/usr/autotool/devel/info:/usr/autotool/stable/info:
  220    6569 [main] expr 1840 environ_init: 0x100105E0: LM_LICENSE_FILE=d:\apps\flexlm\license.dat
  194    6763 [main] expr 1840 environ_init: 0x10010610: LOGONSERVER=\\NEWELL
  202    6965 [main] expr 1840 environ_init: 0x10010630: MAKEFLAGS=
  200    7165 [main] expr 1840 environ_init: 0x10010640: MAKELEVEL=3
  219    7384 [main] expr 1840 environ_init: 0x10010650: MAKEOVERRIDES=${-*-command-variables-*-}
  216    7600 [main] expr 1840 environ_init: 0x10010680: MAKE_MODE=unix
  196    7796 [main] expr 1840 environ_init: 0x10010698: MANPATH=/usr/local/man:/usr/man:/usr/share/man:/usr/autotool/devel/man::/usr/ssl/man
  205    8001 [main] expr 1840 environ_init: 0x100106F8: MFLAGS=
  219    8220 [main] expr 1840 environ_init: 0x10010708: NUMBER_OF_PROCESSORS=2
  214    8434 [main] expr 1840 environ_init: 0x10010728: OS2LIBPATH=G:\WIN2K\system32\os2\dll;
  214    8648 [main] expr 1840 environ_init: 0x10010758: OS=Windows_NT
  197    8845 [main] expr 1840 getwinenv: can't set native for PATH= since no environ yet
  105    8950 [main] expr 1840 normalize_posix_path: src .
  124    9074 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\build_12\m68k-rtems\c\efi332\exec, no-keep-rel, no-add-slash)
  111    9185 [main] expr 1840 normalize_win32_path: D:\cygwin\build_12\m68k-rtems\c\efi332\exec = normalize_win32_path (D:\cygwin\build_12\m68k-rtems\c\efi332\exec)
  128    9313 [main] expr 1840 mount_info::conv_to_posix_path: /build_12/m68k-rtems/c/efi332/exec = conv_to_posix_path (D:\cygwin\build_12\m68k-rtems\c\efi332\exec)
  118    9431 [main] expr 1840 cwdstuff::get: posix /build_12/m68k-rtems/c/efi332/exec
  124    9555 [main] expr 1840 cwdstuff::get: (/build_12/m68k-rtems/c/efi332/exec) = cwdstuff::get (0x22ECE8, 260, 1, 0), errno 0
  255    9810 [main] expr 1840 normalize_posix_path: /build_12/m68k-rtems/c/efi332/exec/ = normalize_posix_path (.)
  117    9927 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/build_12/m68k-rtems/c/efi332/exec)
  141   10068 [main] expr 1840 set_flags: flags: binary (0x2)
  102   10170 [main] expr 1840 mount_info::conv_to_win32_path: src_path /build_12/m68k-rtems/c/efi332/exec, dst D:\cygwin\build_12\m68k-rtems\c\efi332\exec, flags 0xA, rc 0
  194   10364 [main] expr 1840 symlink_info::check: not a symlink
  104   10468 [main] expr 1840 symlink_info::check: 0 = symlink.check (D:\cygwin\build_12\m68k-rtems\c\efi332\exec, 0x22E9A8) (0xA)
  243   10711 [main] expr 1840 path_conv::check: this->path(D:\cygwin\build_12\m68k-rtems\c\efi332\exec), has_acls(1)
  237   10948 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\opt\rtems-4.6\bin, keep-rel, no-add-slash)
  155   11103 [main] expr 1840 normalize_win32_path: D:\cygwin\opt\rtems-4.6\bin = normalize_win32_path (D:\cygwin\opt\rtems-4.6\bin)
  122   11225 [main] expr 1840 mount_info::conv_to_posix_path: /opt/rtems-4.6/bin = conv_to_posix_path (D:\cygwin\opt\rtems-4.6\bin)
  108   11333 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\usr\local\bin, keep-rel, no-add-slash)
  115   11448 [main] expr 1840 normalize_win32_path: D:\cygwin\usr\local\bin = normalize_win32_path (D:\cygwin\usr\local\bin)
  116   11564 [main] expr 1840 mount_info::conv_to_posix_path: /usr/local/bin = conv_to_posix_path (D:\cygwin\usr\local\bin)
  116   11680 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin, keep-rel, no-add-slash)
  103   11783 [main] expr 1840 normalize_win32_path: D:\cygwin\bin = normalize_win32_path (D:\cygwin\bin)
  104   11887 [main] expr 1840 mount_info::conv_to_posix_path: /usr/bin = conv_to_posix_path (D:\cygwin\bin)
  124   12011 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin, keep-rel, no-add-slash)
  110   12121 [main] expr 1840 normalize_win32_path: D:\cygwin\bin = normalize_win32_path (D:\cygwin\bin)
  113   12234 [main] expr 1840 mount_info::conv_to_posix_path: /usr/bin = conv_to_posix_path (D:\cygwin\bin)
  309   12543 [main] expr 1840 win_env::add_cache: posix /opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
  105   12648 [main] expr 1840 win_env::add_cache: native PATH=D:\cygwin\opt\rtems-4.6\bin;D:\cygwin\usr\local\bin;D:\cygwin\bin;D:\cygwin\bin
  115   12763 [main] expr 1840 posify: env var converted to PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
  267   13030 [main] expr 1840 environ_init: 0x100107D0: PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
  423   13453 [main] expr 1840 environ_init: 0x10010770: PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
  249   13702 [main] expr 1840 environ_init: 0x100107B0: PROCESSOR_ARCHITECTURE=x86
  348   14050 [main] expr 1840 environ_init: 0x100109F0: PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
  246   14296 [main] expr 1840 environ_init: 0x100103B8: PROCESSOR_LEVEL=15
  219   14515 [main] expr 1840 environ_init: 0x10010A38: PROCESSOR_REVISION=0209
  193   14708 [main] expr 1840 environ_init: 0x10010A58: PROGRAMFILES=G:\Program Files
  221   14929 [main] expr 1840 environ_init: 0x100103D0: PROMPT=$P$G
  216   15145 [main] expr 1840 environ_init: 0x10010A80: PWD=/build_12/m68k-rtems/c/efi332/exec
  191   15336 [main] expr 1840 environ_init: 0x10010AB0: RTEMS_BSP=efi332
  210   15546 [main] expr 1840 environ_init: 0x10010AC8: SHELL=/bin/bash
  210   15756 [main] expr 1840 environ_init: 0x10010AE0: SHLVL=5
  186   15942 [main] expr 1840 environ_init: 0x10010AF0: SYSTEMDRIVE=G:
  211   16153 [main] expr 1840 environ_init: 0x10010B08: SYSTEMROOT=G:\WIN2K
  209   16362 [main] expr 1840 getwinenv: can't set native for TEMP= since no environ yet
  185   16547 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (g:\temp, no-keep-rel, no-add-slash)
  110   16657 [main] expr 1840 normalize_win32_path: g:\temp = normalize_win32_path (g:\temp)
  122   16779 [main] expr 1840 mount_info::conv_to_posix_path: /cygdrive/g/temp = conv_to_posix_path (g:\temp)
  300   17079 [main] expr 1840 win_env::add_cache: posix /cygdrive/g/temp
   95   17174 [main] expr 1840 win_env::add_cache: native TEMP=g:\temp
   95   17269 [main] expr 1840 posify: env var converted to TEMP=/cygdrive/g/temp
  220   17489 [main] expr 1840 environ_init: 0x10010B38: TEMP=/cygdrive/g/temp
  187   17676 [main] expr 1840 environ_init: 0x10010C78: TERM=cygwin
  181   17857 [main] expr 1840 getwinenv: can't set native for TMP= since no environ yet
  222   18079 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (g:\temp, no-keep-rel, no-add-slash)
  101   18180 [main] expr 1840 normalize_win32_path: g:\temp = normalize_win32_path (g:\temp)
   96   18276 [main] expr 1840 mount_info::conv_to_posix_path: /cygdrive/g/temp = conv_to_posix_path (g:\temp)
  271   18547 [main] expr 1840 win_env::add_cache: posix /cygdrive/g/temp
  150   18697 [main] expr 1840 win_env::add_cache: native TMP=g:\temp
  218   18915 [main] expr 1840 posify: env var converted to TMP=/cygdrive/g/temp
  334   19249 [main] expr 1840 environ_init: 0x10010C98: TMP=/cygdrive/g/temp
  236   19485 [main] expr 1840 environ_init: 0x10010DB8: USER=Administrator
  259   19744 [main] expr 1840 environ_init: 0x10010DD0: USERDOMAIN=NEWELL
  231   19975 [main] expr 1840 environ_init: 0x10010DE8: USERNAME=Administrator
  251   20226 [main] expr 1840 environ_init: 0x10010E08: USERPROFILE=G:\Documents and Settings\Administrator
  245   20471 [main] expr 1840 environ_init: 0x10010E40: WINDIR=G:\WIN2K
  228   20699 [main] expr 1840 environ_init: 0x10010E58: _=/usr/bin/strace
  411   21110 [main] expr 1840 environ_init: 0x10010E70: AC_SUB_CONFIGURE_ARGS= '--prefix=/opt/rtems-4.6' '--host=m68k-rtems' '--build=i686-pc-cygwin' '--target=m68k-rtems' '--disable-posix' '--disable-networking' '--disable-cxx' '--with-target-subdir=m68k-rtems' '--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin' 'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=efi332' 'RTEMS_CPU_MODEL=m68332' 'RTEMS_BSP_FAMILY=efi332' 'CPU_CFLAGS=-mcpu32' 'CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer' '--with-project-root=../../' '--enable-rtemsbsp=efi332'
  252   21362 [main] expr 1840 environ_init: 0x10011080: BUILD_ALIAS=i686-pc-cygwin
  254   21616 [main] expr 1840 environ_init: 0x100110A0: HOST_ALIAS=m68k-rtems
  326   21942 [main] expr 1840 environ_init: 0x100110C0: TARGET_ALIAS=m68k-rtems
  152   22094 [main] expr 1840 pinfo_init: pid 1840, pgid 1840
  185   22279 [main] expr 1840 dtable::extend: size 32, fds 0x616D0CF8
  138   22417 [main] expr 1840 normalize_posix_path: src /etc/passwd
  153   22570 [main] expr 1840 normalize_posix_path: /etc/passwd = normalize_posix_path (/etc/passwd)
  148   22718 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/etc/passwd)
  134   22852 [main] expr 1840 set_flags: flags: binary (0x2)
  129   22981 [main] expr 1840 mount_info::conv_to_win32_path: src_path /etc/passwd, dst D:\cygwin\etc\passwd, flags 0xA, rc 0
  194   23175 [main] expr 1840 symlink_info::check: not a symlink
  129   23304 [main] expr 1840 symlink_info::check: 0 = symlink.check (D:\cygwin\etc\passwd, 0x22E978) (0xA)
  112   23416 [main] expr 1840 path_conv::check: this->path(D:\cygwin\etc\passwd), has_acls(1)
  217   23633 [main] expr 1840 etc::test_file_change: FindFirstFile succeeded
  113   23746 [main] expr 1840 etc::test_file_change: fn[1] D:\cygwin\etc\passwd res 1
  120   23866 [main] expr 1840 etc::init: fn[1] D:\cygwin\etc\passwd, curr_ix 1
  105   23971 [main] expr 1840 pwdgrp::load: /etc/passwd
  480   24451 [main] expr 1840 pwdgrp::load: /etc/passwd curr_lines 4
  106   24557 [main] expr 1840 pwdgrp::load: /etc/passwd load succeeded
  150   24707 [main] expr 1840 normalize_posix_path: src /etc/group
  156   24863 [main] expr 1840 normalize_posix_path: /etc/group = normalize_posix_path (/etc/group)
  111   24974 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/etc/group)
  115   25089 [main] expr 1840 set_flags: flags: binary (0x2)
  103   25192 [main] expr 1840 mount_info::conv_to_win32_path: src_path /etc/group, dst D:\cygwin\etc\group, flags 0xA, rc 0
  155   25347 [main] expr 1840 symlink_info::check: not a symlink
  118   25465 [main] expr 1840 symlink_info::check: 0 = symlink.check (D:\cygwin\etc\group, 0x22E938) (0xA)
  114   25579 [main] expr 1840 path_conv::check: this->path(D:\cygwin\etc\group), has_acls(1)
  206   25785 [main] expr 1840 etc::test_file_change: FindFirstFile succeeded
   97   25882 [main] expr 1840 etc::test_file_change: fn[2] D:\cygwin\etc\group res 1
  107   25989 [main] expr 1840 etc::init: fn[2] D:\cygwin\etc\group, curr_ix 2
   97   26086 [main] expr 1840 pwdgrp::load: /etc/group
  441   26527 [main] expr 1840 pwdgrp::load: /etc/group curr_lines 8
  118   26645 [main] expr 1840 pwdgrp::load: /etc/group load succeeded
  126   26771 [main] expr 1840 cygheap_user::ontherange: what 2, pw 0x10011270
  112   26883 [main] expr 1840 cygheap_user::ontherange: HOME is already in the environment /home/Administrator
  648   27531 [main] expr 1840 sigproc_init: process/signal handling enabled(1)
  333   27864 [main] expr 1840 build_argv: argv[0] = 'expr'
  107   27971 [main] expr 1840 build_argv: argv[1] = 'xbuild_alias'
  105   28076 [main] expr 1840 build_argv: argv[2] = ':'
  242   28318 [sig] expr 1840 wait_sig: entering ReadFile loop, readsig 0x300, myself->sendsig 0x2F8
  296   28614 [main] expr 1840 normalize_posix_path: src .
  111   28725 [main] expr 1840 cwdstuff::get: posix /build_12/m68k-rtems/c/efi332/exec
  101   28826 [main] expr 1840 cwdstuff::get: (/build_12/m68k-rtems/c/efi332/exec) = cwdstuff::get (0x20EA28, 260, 1, 0), errno 0
  114   28940 [main] expr 1840 normalize_posix_path: /build_12/m68k-rtems/c/efi332/exec/ = normalize_posix_path (.)
  129   29069 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/build_12/m68k-rtems/c/efi332/exec)
  119   29188 [main] expr 1840 set_flags: flags: binary (0x2)
  117   29305 [main] expr 1840 mount_info::conv_to_win32_path: src_path /build_12/m68k-rtems/c/efi332/exec, dst D:\cygwin\build_12\m68k-rtems\c\efi332\exec, flags 0xA, rc 0
  162   29467 [main] expr 1840 symlink_info::check: not a symlink
  115   29582 [main] expr 1840 symlink_info::check: 0 = symlink.check (D:\cygwin\build_12\m68k-rtems\c\efi332\exec, 0x20E6E8) (0xA)
  101   29683 [main] expr 1840 path_conv::check: this->path(D:\cygwin\build_12\m68k-rtems\c\efi332\exec), has_acls(1)
  116   29799 [main] expr 1840 build_fh_pc: fh 0x616D0E30
  547   30346 [main] expr 1840 read_sd: file = D:\cygwin\build_12\m68k-rtems\c\efi332\exec: len=236
  352   30698 [main] expr 1840 check_file_access: flags 4, ret 0
  211   30909 [main] expr 1840 fhandler_base::fhaccess: returning 0
  115   31024 [main] expr 1840 fhandler_disk_file::opendir: 0x10011550 = opendir (/build_12/m68k-rtems/c/efi332/exec)
  216   31240 [main] expr 1840 fhandler_disk_file::readdir: 0x10011554 = readdir (0x10011550) (.)
  139   31379 [main] expr 1840 fhandler_disk_file::readdir: 0x10011554 = readdir (0x10011550) (..)
  161   31540 [main] expr 1840 fhandler_disk_file::readdir: 0x0 = readdir (0x10011550)
  118   31658 [main] expr 1840 fhandler_disk_file::closedir: 0 = closedir (0x10011550)
  463   32121 [main] expr 1840 closedir: 0 = closedir (0x212CC0)
  298   32419 [main] expr 1840 globify: argv[3] = '.*[^_abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789]'
  223   32642 [main] expr 1840 build_argv: argc 4
  203   32845 [main] expr 1840 build_fh_pc: fh 0x616D0E30
  139   32984 [main] expr 1840 open_shared: name (null), shared 0xA020000 (wanted 0xA020000), h 0x2E8
  119   33103 [main] expr 1840 _pinfo::set_ctty: checking if /dev/tty-1 changed
  112   33215 [main] expr 1840 _pinfo::set_ctty: attached tty1073741824 sid 1840, pid 1840, tty->pgid 1840, tty->sid 1840
  130   33345 [main] expr 1840 _pinfo::set_ctty: resetting tty1073741824 sid.  Was 1840, now 1840.  pgid was 0, now 1840.
 1557   34902 [main] expr 1840 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
  165   35067 [main] expr 1840 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
  111   35178 [main] expr 1840 fhandler_base::set_flags: filemode set to binary
  290   35468 [main] expr 1840 fhandler_console::open: incremented open_fhs, now 1
  132   35600 [main] expr 1840 fhandler_console::open: opened conin$ 0x3, conout$ 0x13
  147   35747 [main] expr 1840 fhandler_console::output_tcsetattr: 0 = tcsetattr (,A020018) (ENABLE FLAGS 3) (lflag 107 oflag 9)
  163   35910 [main] expr 1840 dtable::init_std_file_from_handle: fd 0, handle 0xB
  308   36218 [main] expr 1840 handle_to_fn: nt name '\Device\Null'
 2082   38300 [main] expr 1840 handle_to_fn: derived path '\Device\Null'
  149   38449 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (\Device\Null, no-keep-rel, no-add-slash)
  131   38580 [main] expr 1840 cwdstuff::get: posix /build_12/m68k-rtems/c/efi332/exec
  109   38689 [main] expr 1840 cwdstuff::get: (D:\cygwin\build_12\m68k-rtems\c\efi332\exec) = cwdstuff::get (0x226978, 260, 0, 0), errno 0
  103   38792 [main] expr 1840 normalize_win32_path: D:\Device\Null = normalize_win32_path (\Device\Null)
  104   38896 [main] expr 1840 mount_info::conv_to_posix_path: /cygdrive/d/Device/Null = conv_to_posix_path (\Device\Null)
  112   39008 [main] expr 1840 normalize_posix_path: src /cygdrive/d/Device/Null
  121   39129 [main] expr 1840 normalize_posix_path: /cygdrive/d/Device/Null = normalize_posix_path (/cygdrive/d/Device/Null)
  108   39237 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/cygdrive/d/Device/Null)
  127   39364 [main] expr 1840 mount_info::cygdrive_win32_path: src '/cygdrive/d/Device/Null', dst 'd:\Device\Null'
   97   39461 [main] expr 1840 set_flags: flags: binary (0x2)
  108   39569 [main] expr 1840 mount_info::conv_to_win32_path: src_path /cygdrive/d/Device/Null, dst d:\Device\Null, flags 0x22, rc 0
  205   39774 [main] expr 1840 symlink_info::check: GetFileAttributes (d:\Device\Null) failed
  115   39889 [main] expr 1840 geterrno_from_win_error: windows error 3 == errno 2
  192   40081 [main] expr 1840 symlink_info::check: GetFileAttributes (d:\Device\Null.lnk) failed
  120   40201 [main] expr 1840 geterrno_from_win_error: windows error 3 == errno 2
  145   40346 [main] expr 1840 symlink_info::check: 0 = symlink.check (d:\Device\Null, 0x22E7A8) (0x22)
  258   40604 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/cygdrive/d/Device)
  180   40784 [main] expr 1840 mount_info::cygdrive_win32_path: src '/cygdrive/d/Device', dst 'd:\Device'
  147   40931 [main] expr 1840 set_flags: flags: binary (0x2)
  107   41038 [main] expr 1840 mount_info::conv_to_win32_path: src_path /cygdrive/d/Device, dst d:\Device, flags 0x22, rc 0
  177   41215 [main] expr 1840 symlink_info::check: GetFileAttributes (d:\Device) failed
  158   41373 [main] expr 1840 geterrno_from_win_error: windows error 2 == errno 2
  180   41553 [main] expr 1840 symlink_info::check: GetFileAttributes (d:\Device.lnk) failed
  106   41659 [main] expr 1840 geterrno_from_win_error: windows error 2 == errno 2
  113   41772 [main] expr 1840 symlink_info::check: 0 = symlink.check (d:\Device, 0x22E7A8) (0x22)
  113   41885 [main] expr 1840 mount_info::conv_to_win32_path: conv_to_win32_path (/cygdrive/d)
  107   41992 [main] expr 1840 mount_info::cygdrive_win32_path: src '/cygdrive/d', dst 'd:\'
  100   42092 [main] expr 1840 set_flags: flags: binary (0x2)
   98   42190 [main] expr 1840 mount_info::conv_to_win32_path: src_path /cygdrive/d, dst d:\, flags 0x22, rc 0
  156   42346 [main] expr 1840 symlink_info::check: not a symlink
  111   42457 [main] expr 1840 symlink_info::check: 0 = symlink.check (d:\, 0x22E7A8) (0x22)
  106   42563 [main] expr 1840 path_conv::check: this->path(d:\Device\Null), has_acls(1)
  133   42696 [main] expr 1840 build_fh_pc: fh 0x616D1038
  118   42814 [main] expr 1840 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
  129   42943 [main] expr 1840 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
  118   43061 [main] expr 1840 fhandler_base::set_flags: filemode set to binary
  110   43171 [main] expr 1840 fhandler_base::init: created new fhandler_base for handle 0x1D4, bin 1
  126   43297 [main] expr 1840 dtable::init_std_file_from_handle: fd 1, handle 0x1D4
  159   43456 [main] expr 1840 build_fh_pc: fh 0x616D1240
  109   43565 [main] expr 1840 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
  113   43678 [main] expr 1840 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
   98   43776 [main] expr 1840 fhandler_base::set_flags: filemode set to binary
  105   43881 [main] expr 1840 fhandler_base::init: created new fhandler_base for handle 0x2F4, bin 1
   99   43980 [main] expr 1840 dtable::init_std_file_from_handle: fd 2, handle 0x2F4
  550   44530 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin\cygiconv-2.dll, keep-rel, no-add-slash)
  116   44646 [main] expr 1840 normalize_win32_path: D:\cygwin\bin\cygiconv-2.dll = normalize_win32_path (D:\cygwin\bin\cygiconv-2.dll)
  116   44762 [main] expr 1840 mount_info::conv_to_posix_path: /usr/bin/cygiconv-2.dll = conv_to_posix_path (D:\cygwin\bin\cygiconv-2.dll)
  550   45312 [main] expr 1840 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin\cygintl-2.dll, keep-rel, no-add-slash)
  112   45424 [main] expr 1840 normalize_win32_path: D:\cygwin\bin\cygintl-2.dll = normalize_win32_path (D:\cygwin\bin\cygintl-2.dll)
  100   45524 [main] expr 1840 mount_info::conv_to_posix_path: /usr/bin/cygintl-2.dll = conv_to_posix_path (D:\cygwin\bin\cygintl-2.dll)
  194   45718 [main] expr 1840 dll_crt0_1: user_data->main 0x401AE0
  132   45850 [main] expr 1840 wait_for_sigthread: wait_sig_inited 0x314
 1796   47646 [main] expr 1840 fhandler_base::fstat_by_handle: 0 = GetFileInformationByHandle (d:\Device\Null, 468)
  123   47769 [main] expr 1840 get_file_attribute: file: d:\Device\Null
  265   48034 [main] expr 1840 cygpsid::debug_print: get_sids_info: owner SID = S-1-5-32-544
  125   48159 [main] expr 1840 cygpsid::debug_print: get_sids_info: group SID = S-1-5-18
  121   48280 [main] expr 1840 get_info_from_sd: ACL = 1FF, uid 544, gid 18
  215   48495 [main] expr 1840 fhandler_base::fstat_helper: 0 = fstat (, 0x22EE70) st_atime=0 st_size=0, st_mode=0x81FF, st_ino=886905255, sizeof=96
  115   48610 [main] expr 1840 fstat64: 0 = fstat (1, 0x22EE70)
  424   49034 [main] expr 1840 writev: writev (1, 0x22EEA0, 1)
  113   49147 [main] expr 1840 fhandler_base::write: binary write
  119   49266 [main] expr 1840 fhandler_base::write: 2 = write (0x100116E8, 2)
  116   49382 [main] expr 1840 writev: 2 = write (1, 0x22EEA0, 1), errno 0
  111   49493 [main] expr 1840 close: close (1)
   97   49590 [main] expr 1840 fhandler_base::close: closing '/cygdrive/d/Device/Null' handle 0x1D4
  124   49714 [main] expr 1840 close: 0 = close (1)
  550   50264 [main] expr 1840 do_exit: do_exit (1), exit_state 0
  110   50374 [main] expr 1840 void: 0x0 = signal (20, 0x1)
  109   50483 [main] expr 1840 void: 0x0 = signal (1, 0x1)
  124   50607 [main] expr 1840 void: 0x0 = signal (2, 0x1)
  120   50727 [main] expr 1840 void: 0x0 = signal (3, 0x1)
  153   50880 [main] expr 1840 fhandler_console::close: decremented open_fhs, now 0
  118   50998 [main] expr 1840 sigproc_terminate: entering
  131   51129 [sig] expr 1840 wait_sig: done
    1   51130 [main] expr 1840 proc_terminate: nchildren 0, nzombies 0
  221   51351 [main] expr 1840 proc_terminate: leaving
    1   51352 [sig] expr 1840 _cygtls::remove: wait 0x0
  479   51831 [main] expr 1840 __to_clock_t: dwHighDateTime 0, dwLowDateTime 312500
  106   51937 [main] expr 1840 __to_clock_t: total 00000000 0000001F
  127   52064 [main] expr 1840 __to_clock_t: dwHighDateTime 0, dwLowDateTime 468750
  134   52198 [main] expr 1840 __to_clock_t: total 00000000 0000002E
  874   53072 [main] expr 1840 _pinfo::exit: Calling ExitProcess 1
