cygwin build_alias issue (and a possible workaround...)
Bogdan Vacaliuc
bvacaliuc at ngit.com
Sat Sep 4 13:57:24 UTC 2004
Hi Scott,
Ugh. You have a bizarre editor. Your file contains some leading 0x240
characters. I'm zipping you my file and attaching it. Here's the analysis:
[/opt/rtems-4.6/bin] diff expr.sn expr.bv
1,12c1,10
< #!/bin/sh
< echo "Calling expr with" "$@" >> ${HOME}/expr.log
< if result=`/usr/bin/expr "$@"` ; then
< echo "expr $@ result $result status 0" >> ${HOME}/expr.log
< echo $result
< exit 0;
< else
< echo "expr $@ result $result status !0" >> ${HOME}/expr.log
< echo $result
< exit 1;
< fi
\ No newline at end of file
> #!/bin/sh
> echo $result
> exit 0;
> else
> echo $result
> exit 1;
> fi
[/opt/rtems-4.6/bin] od -c expr.sn
0000000 # ! / b i n / s h \r \n e c h o
0000020 " C a l l i n g e x p r w i
0000040 t h " " $ @ " > > $ { H O
0000060 M E } / e x p r . l o g \r \n \r \n
0000100 i f r e s u l t = ` / u s r /
0000120 b i n / e x p r " $ @ " ` ;
0000140 t h e n \r \n 240 240 240 e c h o
0000160 " e x p r $ @ r e s u l t
0000200 $ r e s u l t s t a t u s 0
0000220 " > > $ { H O M E } / e x p
0000240 r . l o g \r \n 240 240 240 e c h o
0000260 $ r e s u l t \r \n 240 240 240 e x i
0000300 t 0 ; \r \n e l s e \r \n 240 240 240
0000320 e c h o " e x p r $ @ r e
0000340 s u l t $ r e s u l t s t a
0000360 t u s ! 0 " > > $ { H O M
0000400 E } / e x p r . l o g \r \n 240 240 240
0000420 e c h o $ r e s u l t \r \n 240
0000440 240 240 e x i t 1 ; \r \n f i
0000456
[/opt/rtems-4.6/bin] od -c expr.bv
0000000 # ! / b i n / s h \n i f r e s
0000020 u l t = ` / u s r / b i n / e x
0000040 p r " $ @ " ` ; t h e n \n
0000060 e c h o " e x p r $
0000100 @ r e s u l t $ r e s u l t
0000120 s t a t u s 0 " > > $ {
0000140 H O M E } / e x p r . l o g \n
0000160 e c h o $ r e s u l t \n
0000200 e x i t 0 ; \n e l s e
0000220 \n e c h o " e x p r
0000240 $ @ r e s u l t $ r e s u l
0000260 t s t a t u s ! 0 " > >
0000300 $ { H O M E } / e x p r . l o g
0000320 \n e c h o $ r e s u l
0000340 t \n e x i t 1 ; \n f i
0000360 \n
0000361
> >SharedSection=1024,3072,128,128
> SharedSection=1024,3072,512,512
That should be ok; its what I started out with; I've been trying to 'stress'
my system.
> >Its going to be a long weekend...
> Absolutely.
I wait for your results...
-bogdan
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040904/ecf37ac3/attachment.bin>
