[powerpc bsp] linkcmd.dl?
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Sat Sep 4 20:47:29 UTC 2004
On Sat, Sep 04, 2004 at 03:36:39PM -0400, Gene Smith wrote:
> Most of the powerpc bsp's have file in the start directory called
> linkcmd.dl which differs from the standard linkcmd file. Does anyone
> know what these linkcmd.dl files are for? I can't find them mentioned in
> the manual. The linkcmd files all mention "gnu.linkonce" while the *.dl
> files don't.
From helas403/.../linkcmds:
* This file is intended to be used together with flashentry.s
* it will generate a ROM that can be started directly after powerup reset
From helas403/.../linkcmds.dl:
* This file is intended to be used together with dlentry.s
* it will generate downloadable code
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20040904/9f499a02/attachment.bin>
