RTEMS Evaluation CD Available
Till Straumann strauman at slac.stanford.edu
Wed Sep 8 15:58:05 UTC 2004
Wolfram Wadepohl wrote:
> Hello,
> i burned the image using NERO. All directory and file names apear in
> uppercase and the links inside are lowercase. Did i make a mistake?
Did you check your mount options? I don't fully undertand all the standards
but it seems that with rock-ridge enabled, you should get unix filenames.
Works fine for me (RH9 on i386, mandrake9.1 on ppc).
T.
