cygwin build_alias issue (and a possible workaround...)
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Sep 13 02:57:57 UTC 2004
Bogdan Vacaliuc wrote:
> List,
> See http://cygwin.com/ml/cygwin/2004-09/msg00570.html for the latest on the "build_alias" issue.  There is a simplified test
> methodology now.
> I must suspend my debug effort for the time being.
> Best Regards,
> -bogdan
> (The rtems list mailer keeps rejecting my posts due to the attachments; and I havent figured out a better way to satisfy both the
> rtems and cygwin mailers.  Maybe I shouldn't cc: the lists...)
There is a limit on the size of attachments to the RTEMS list.  It
is 100000 bytes.  DId you trip it?
You also have to send from a subscribed address.
