rtems_task_delete does not remove thread (rtems 4.6.0pre5)
Valery Pykhtin
pykhtin at prosoft.ural.ru
Sat Sep 18 09:14:10 UTC 2004
Hi All,
Currently I'm trying to accomplish this test:
rtems_task ThreadFx(rtems_task_argument)
printf("starting\n"); printf("exiting\n");
int Cycle()
rtems_status_code rv; rtems_id tr;
rv =
rtems_task_create(rtems_build_name('t','e','s','t'),120,4096,0,0,&tr);
if (rv!=RTEMS_SUCCESSFUL) { printf("create failure %d\n",rv); return
rtems_task_start(tr,ThreadFx,0);
rtems_task_wake_after(2000);
rv = rtems_task_delete(tr);
if (rv!=RTEMS_SUCCESSFUL) { printf("delete failure %d\n",rv); }
return 1;
void ThreadTest()
while(Cycle());
The problem is that rtems_task_delete does not remove the task reporing
RTEMS_INVALID_ID.
The worst thing in this case is that the space allocated to the task isn't
freed too. After a few Cycles
rtems_task_create reports RTEMS_TOO_MANY.
If I remove rtems_task_wake_after(2000) - all goes well... but this is not
what I want.
Is the idea I should put rtem_task_delete into the ThreadFx() ? I've tried
it and all goes well...
Best regards,
Valery
