Not quite (Cygwin build_alias bug hunt)
Bogdan Vacaliuc bvacaliuc at ngit.com
Sat Sep 18 18:43:35 UTC 2004
Hi Scott,
> This step failed for me:
> $ ./bash-2.05b-16.sh prep
> ./bash-2.05b-16.sh: line 72: syntax error near unexpected token `&&'
> ./bash-2.05b-16.sh: line 72: `  && touch ${srcdir}/configure'
Hmm.  That's strange.
> I changed the shell script to:
> prep() {
>   (cd ${topdir} && \
>   tar xv${opt_decomp}f ${src_orig_pkg} ; \
>   cd ${topdir} && \
>   patch -p0 < ${src_patch}  && touch ${srcdir}/configure  &&
> mkdirs ) }
> And things seemed to work out.
Oh, putting everything on the same line effectively.  Did you refresh your (a)sh binary from the cygwin distro instead of the
source-compiled one (if you ever used it?).
I just tried an equivalent sequence in both (a)sh and bash.  There appears to be a slight parsing difference, in which bash seems to
introduce a gratuitous ';' after the patch -p0 < ${src_patch} <newline> statement.
I think your mod is correct and will work for both cases.  You might suggest it to the cygwin bash maintainer.
This happened because you are using /bin/sh.exe <= /bin/bash.exe, I think.
Sigh.
It would be nice to address the part of the rtems document that says you should copy /bin/bash.exe into /bin/sh.exe.  Either to
determine that 'yes, it is necessary, and this is why... [so that the guilty piece of software could be fixed]', or 'no, we don't
need to do that anymore'.
My hunch is that with the Cygwin of today, it is not needed anymore.
> >	$ ( cd bash-2.05b ; make strip )
> I think you mean "cd bash-2.05b/.build" here.
You are always catching my sloppyness.  Thanks!
> I'm running the test script and a efi332 bsp build right
> now...we'll see how this works.  (Oh, I did restore the
> original cygwin1.dll as well.)
Good!
-bogdan
