RTEMS build error.
Simone Finotti
simone.finotti at ocem.com
Fri Sep 24 09:11:55 UTC 2004
Hello,
I'm trying to build RTEMS, with 'arm-rtems' as target. I've configured
it - correctly, I think - but when I launch 'make all', after some
minutes, I get this error:
'opt/rtems-4.6/lib/gcc-lib/arm-rtems/3.2.3/../../../../arm-rtems/bin/ld:
region FLASH is full (o-optimize/pppd.obj section .text).'
I'm compiling under Linux RedHat 7.3 and every tools seems to be
correctly in place (under the '/opt/rtems-4.6' directory). I configured
running '../rtems-4.6/configure --target=arm-rtems', following the
online-documentation.
What could it be the problem?
Thank you in advance,
Simone
