recv timeout
Angelo Fraietta afraiett at bigpond.net.au
Mon Sep 27 02:34:41 UTC 2004
Thanks - I'll give it a go
Ian Caddy wrote:
> We use the setsockopt as described by Eric.
> Here is an example function that we use in our system:
> int SetSocketTimeout(int connectSocket, int milliseconds)
>    struct timeval tv;
>     tv.tv_sec = milliseconds / 1000 ;
>     tv.tv_usec = ( milliseconds % 1000) * 1000  ;
>    return setsockopt (connectSocket, SOL_SOCKET, SO_RCVTIMEO, (char
> *)&tv, sizeof tv);
> Then when you are waiting to receive a packet, use the following
> function:
>    iRc = recv(connectSocket, pTmpRxBuffer, u16MessageDataLen, 0 );
>    if (iRc == 0)
>       /* Socket has been disconnected */
>       printf("\nSocket EOF\n");
>       close(connectSocket);
>       connectSocket = 0;
>       return u32Rc;
>    if(iRc < 0)
>       printf("\nSocket recv returned %d, errno %d\n",iRc,errno);
>       close(connectSocket); /* Close socket if we get an error */
>       connectSocket = 0;
> If iRc is positive, it gives you the number of chars received.
> I hope this helps.
> regards,
> Ian Caddy
> Angelo Fraietta wrote:
>> Eric Norum wrote:
>>> On Sep 24, 2004, at 11:57 AM, Steve Holle wrote:
>>>> I have a simple socket application and I would like to timeout recv
>>>> after a fixed period of inactivity.  I found an article showing how
>>>> to do it using select but I am under the impression this is not
>>>> supported.
>>>> What would be the best way to accomplish the timeout.
>>> select() works with sockets, but is a very expensive call.  A better
>>> technique is to use the SO_RCVTIMEO socket option.
>> Do you have an example or code snippet using it?.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
