Wiki Accounts
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Sep 28 11:16:29 UTC 2004
Ralf Corsepius wrote:
> On Tue, 2004-09-28 at 00:53, Aaron J. Grier wrote:
>>On Mon, Sep 27, 2004 at 06:15:55PM +0200, Ralf Corsepius wrote:
>>>On Mon, 2004-09-27 at 17:30, Joel Sherrill  wrote:
>>>>I was wrong.  You can add yourself a personal page/account.
>>>How? Detailed instructions, please.
>>>ATM, to me, this Wiki appears to be plain simple non-functional.
>>* go to http://www.rtems.com/phpwiki/ .
>>* in the bottom right corner next to the "sign in as" button, put your
>>  desired username and click the "sign in as" button.
>>* the main page will reload again, this time it will say "authenticated
>>  as UserName" at the bottom.  there will be a question mark next to the
>>  username.  click on the question mark and fill out the profile page.
> Thanks, however, this is exactly what I did and what only seems to be
> working at random for me.
> I have filed screenshots of 2 failing attempts to RTEMS bug database.
> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=685
> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=684
I think the trick is to create your personal page as soon as you log in.
If you leave without one, it appears to be hard to get back in.
What I am doing is "Finding" your PersonalPage.  It doesn't exist, so
I create it with some dummy modification, then check that I can login as
you and it has always worked (so far).
What is really happening I don't know.
>>* once you are logged in you can change your password by clicking on
>>  "Preferences" at the top of any page.
> When I manage to "sign in" (I can sign-in using an account which, AFAICT
> Joel has created manually) PhpWiki replies:
> Password cannot be changed. No changes.
There really is no password system enabled in our installation.  PhpWiki
appears to support various password schemes but so far I can't make any
of them work. When I do figure it out, I will go through and assign all
users a password and email it to you.
> Ralf
