error 105
Chris Johns
chrisj at rtems.org
Thu Sep 30 21:49:25 UTC 2004
Steve Holle wrote:
> I'm trying to get BOOTP running, and when I enable it I get the following :
> RTEMS: BOOTP call failed -- error 105
> Where would I find out what error 105 is?
To find I do:
$ cd rtems/cpukit
$ grep -r "BOOTP call failed" *
libnetworking/nfs/bootp_subr.c: panic("BOOTP call failed -- error %d",
error);
> Any idea what's causing it?
Then looking at the code I see it is an error code from the function
'bootpc_call'. Another grep shows this function is in the same file, and
looks like it is the result of calls to socket type functions.
A look in errno.h gives:
#define ENOBUFS 105 /* No buffer space available */
I see 'bootp_call' returns this value if no mbufs are available.
It your networking code ok ?
Chris Johns
