cygwin build_alias issue
Scott Newell
newell at cei.net
Wed Sep 1 19:34:11 UTC 2004
At 01:58 PM 9/1/2004 , Ralf Corsepius wrote:
>Your configure script log indicates the expr call above to fail, while
>its counterpart in check.sh doesn't seem to fail. I had hoped it would
>fail and give an indication for what might be going wrong :(
Did you notice that "0" after the first "expr xbuild_alias :" command?
Significant at all?
>[To exclude DUEs: /dev/null is a writable character device?]
How would I know?
$ ls -l /dev/null
crw-rw-rw- 1 Administ None 1, 3 Sep 1 14:06 /dev/null
No errors if I cat or echo redirect to /dev/null, either.
>Next try: Could you try to strace this expr call in the original
>configure script? I.e. to change the expr call into something similar to
> strace -o /tmp/log -f expr "x...."
ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
to:
strace -o /tmp/strace.log ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
doesn't seem to work:
+ strace -o /tmp/strace.log ac_optarg=/opt/rtems-4.6
strace.exe: error creating process ac_optarg=/opt/rtems-4.6, (error 2)
maybe this:
ac_optarg=`strace -o /tmp/strace.log expr "x$ac_option" : 'x[^=]*=\(.*\)'`
strace logfile attached.
newell
Program name: D:\cygwin\bin\expr.exe (2188)
App version: 1005.0, api: 0.88
DLL version: 1005.10, api: 0.116
DLL build: 2004-05-25 22:07
OS version: Windows NT-5.0
Heap size: 402653184
Date/Time: 2004-09-01 14:25:37
860 1918 [main] expr 2188 environ_init: 0x10010008: !D:=D:\cygwin\bin
215 2133 [main] expr 2188 environ_init: 0x10010250: !G:=G:\Documents and Settings\Administrator\Desktop
220 2353 [main] expr 2188 environ_init: 0x10010288: ALLUSERSPROFILE=G:\Documents and Settings\All Users
257 2610 [main] expr 2188 environ_init: 0x100102C0: APPDATA=G:\Documents and Settings\Administrator\Application Data
211 2821 [main] expr 2188 environ_init: 0x10010308: COMMONPROGRAMFILES=G:\Program Files\Common Files
206 3027 [main] expr 2188 environ_init: 0x10010340: COMPUTERNAME=NEWELL
206 3233 [main] expr 2188 environ_init: 0x10010358: COMSPEC=G:\WIN2K\system32\cmd.exe
203 3436 [main] expr 2188 environ_init: 0x10010380: CONFIG_SHELL=/bin/bash
208 3644 [main] expr 2188 environ_init: 0x100103A0: CVS_RSH=/bin/ssh
275 3919 [main] expr 2188 getwinenv: can't set native for HOME= since no environ yet
238 4157 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\home\Administrator, no-keep-rel, no-add-slash)
153 4310 [main] expr 2188 normalize_win32_path: D:\cygwin\home\Administrator = normalize_win32_path (D:\cygwin\home\Administrator)
142 4452 [main] expr 2188 mount_info::conv_to_posix_path: /home/Administrator = conv_to_posix_path (D:\cygwin\home\Administrator)
310 4762 [main] expr 2188 win_env::add_cache: posix /home/Administrator
113 4875 [main] expr 2188 win_env::add_cache: native HOME=D:\cygwin\home\Administrator
110 4985 [main] expr 2188 posify: env var converted to HOME=/home/Administrator
220 5205 [main] expr 2188 environ_init: 0x100103E0: HOME=/home/Administrator
209 5414 [main] expr 2188 environ_init: 0x10010530: HOMEDRIVE=G:
206 5620 [main] expr 2188 environ_init: 0x10010548: HOMEPATH=\
195 5815 [main] expr 2188 environ_init: 0x10010558: HOSTNAME=newell
220 6035 [main] expr 2188 environ_init: 0x10010570: INFOPATH=/usr/local/info:/usr/info:/usr/share/info:/usr/autotool/devel/info:/usr/autotool/stable/info:
253 6288 [main] expr 2188 environ_init: 0x100105E0: LM_LICENSE_FILE=d:\apps\flexlm\license.dat
197 6485 [main] expr 2188 environ_init: 0x10010610: LOGONSERVER=\\NEWELL
210 6695 [main] expr 2188 environ_init: 0x10010630: MAKEFLAGS=
218 6913 [main] expr 2188 environ_init: 0x10010640: MAKELEVEL=3
201 7114 [main] expr 2188 environ_init: 0x10010650: MAKEOVERRIDES=${-*-command-variables-*-}
212 7326 [main] expr 2188 environ_init: 0x10010680: MAKE_MODE=unix
223 7549 [main] expr 2188 environ_init: 0x10010698: MANPATH=/usr/local/man:/usr/man:/usr/share/man:/usr/autotool/devel/man::/usr/ssl/man
211 7760 [main] expr 2188 environ_init: 0x100106F8: MFLAGS=
205 7965 [main] expr 2188 environ_init: 0x10010708: NUMBER_OF_PROCESSORS=2
207 8172 [main] expr 2188 environ_init: 0x10010728: OS2LIBPATH=G:\WIN2K\system32\os2\dll;
206 8378 [main] expr 2188 environ_init: 0x10010758: OS=Windows_NT
208 8586 [main] expr 2188 getwinenv: can't set native for PATH= since no environ yet
123 8709 [main] expr 2188 normalize_posix_path: src .
111 8820 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\build_09\m68k-rtems\c\efi332\exec, no-keep-rel, no-add-slash)
112 8932 [main] expr 2188 normalize_win32_path: D:\cygwin\build_09\m68k-rtems\c\efi332\exec = normalize_win32_path (D:\cygwin\build_09\m68k-rtems\c\efi332\exec)
108 9040 [main] expr 2188 mount_info::conv_to_posix_path: /build_09/m68k-rtems/c/efi332/exec = conv_to_posix_path (D:\cygwin\build_09\m68k-rtems\c\efi332\exec)
115 9155 [main] expr 2188 cwdstuff::get: posix /build_09/m68k-rtems/c/efi332/exec
106 9261 [main] expr 2188 cwdstuff::get: (/build_09/m68k-rtems/c/efi332/exec) = cwdstuff::get (0x22ECE8, 260, 1, 0), errno 0
162 9423 [main] expr 2188 normalize_posix_path: /build_09/m68k-rtems/c/efi332/exec/ = normalize_posix_path (.)
113 9536 [main] expr 2188 mount_info::conv_to_win32_path: conv_to_win32_path (/build_09/m68k-rtems/c/efi332/exec)
132 9668 [main] expr 2188 set_flags: flags: binary (0x2)
107 9775 [main] expr 2188 mount_info::conv_to_win32_path: src_path /build_09/m68k-rtems/c/efi332/exec, dst D:\cygwin\build_09\m68k-rtems\c\efi332\exec, flags 0xA, rc 0
179 9954 [main] expr 2188 symlink_info::check: not a symlink
119 10073 [main] expr 2188 symlink_info::check: 0 = symlink.check (D:\cygwin\build_09\m68k-rtems\c\efi332\exec, 0x22E9A8) (0xA)
247 10320 [main] expr 2188 path_conv::check: this->path(D:\cygwin\build_09\m68k-rtems\c\efi332\exec), has_acls(1)
230 10550 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\opt\rtems-4.6\bin, keep-rel, no-add-slash)
107 10657 [main] expr 2188 normalize_win32_path: D:\cygwin\opt\rtems-4.6\bin = normalize_win32_path (D:\cygwin\opt\rtems-4.6\bin)
116 10773 [main] expr 2188 mount_info::conv_to_posix_path: /opt/rtems-4.6/bin = conv_to_posix_path (D:\cygwin\opt\rtems-4.6\bin)
111 10884 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\usr\local\bin, keep-rel, no-add-slash)
103 10987 [main] expr 2188 normalize_win32_path: D:\cygwin\usr\local\bin = normalize_win32_path (D:\cygwin\usr\local\bin)
108 11095 [main] expr 2188 mount_info::conv_to_posix_path: /usr/local/bin = conv_to_posix_path (D:\cygwin\usr\local\bin)
109 11204 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin, keep-rel, no-add-slash)
114 11318 [main] expr 2188 normalize_win32_path: D:\cygwin\bin = normalize_win32_path (D:\cygwin\bin)
114 11432 [main] expr 2188 mount_info::conv_to_posix_path: /usr/bin = conv_to_posix_path (D:\cygwin\bin)
109 11541 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin, keep-rel, no-add-slash)
128 11669 [main] expr 2188 normalize_win32_path: D:\cygwin\bin = normalize_win32_path (D:\cygwin\bin)
116 11785 [main] expr 2188 mount_info::conv_to_posix_path: /usr/bin = conv_to_posix_path (D:\cygwin\bin)
314 12099 [main] expr 2188 win_env::add_cache: posix /opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
104 12203 [main] expr 2188 win_env::add_cache: native PATH=D:\cygwin\opt\rtems-4.6\bin;D:\cygwin\usr\local\bin;D:\cygwin\bin;D:\cygwin\bin
117 12320 [main] expr 2188 posify: env var converted to PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
197 12517 [main] expr 2188 environ_init: 0x100107D0: PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/usr/bin
201 12718 [main] expr 2188 environ_init: 0x10010770: PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
209 12927 [main] expr 2188 environ_init: 0x100107B0: PROCESSOR_ARCHITECTURE=x86
212 13139 [main] expr 2188 environ_init: 0x100109F0: PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
204 13343 [main] expr 2188 environ_init: 0x100103B8: PROCESSOR_LEVEL=15
227 13570 [main] expr 2188 environ_init: 0x10010A38: PROCESSOR_REVISION=0209
205 13775 [main] expr 2188 environ_init: 0x10010A58: PROGRAMFILES=G:\Program Files
205 13980 [main] expr 2188 environ_init: 0x100103D0: PROMPT=$P$G
203 14183 [main] expr 2188 environ_init: 0x10010A80: PWD=/build_09/m68k-rtems/c/efi332/exec
205 14388 [main] expr 2188 environ_init: 0x10010AB0: RTEMS_BSP=efi332
210 14598 [main] expr 2188 environ_init: 0x10010AC8: SHELL=/bin/bash
210 14808 [main] expr 2188 environ_init: 0x10010AE0: SHLVL=5
195 15003 [main] expr 2188 environ_init: 0x10010AF0: SYSTEMDRIVE=G:
206 15209 [main] expr 2188 environ_init: 0x10010B08: SYSTEMROOT=G:\WIN2K
205 15414 [main] expr 2188 getwinenv: can't set native for TEMP= since no environ yet
221 15635 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (g:\temp, no-keep-rel, no-add-slash)
114 15749 [main] expr 2188 normalize_win32_path: g:\temp = normalize_win32_path (g:\temp)
139 15888 [main] expr 2188 mount_info::conv_to_posix_path: /cygdrive/g/temp = conv_to_posix_path (g:\temp)
315 16203 [main] expr 2188 win_env::add_cache: posix /cygdrive/g/temp
105 16308 [main] expr 2188 win_env::add_cache: native TEMP=g:\temp
110 16418 [main] expr 2188 posify: env var converted to TEMP=/cygdrive/g/temp
214 16632 [main] expr 2188 environ_init: 0x10010B38: TEMP=/cygdrive/g/temp
209 16841 [main] expr 2188 environ_init: 0x10010C78: TERM=cygwin
200 17041 [main] expr 2188 getwinenv: can't set native for TMP= since no environ yet
210 17251 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (g:\temp, no-keep-rel, no-add-slash)
109 17360 [main] expr 2188 normalize_win32_path: g:\temp = normalize_win32_path (g:\temp)
116 17476 [main] expr 2188 mount_info::conv_to_posix_path: /cygdrive/g/temp = conv_to_posix_path (g:\temp)
306 17782 [main] expr 2188 win_env::add_cache: posix /cygdrive/g/temp
115 17897 [main] expr 2188 win_env::add_cache: native TMP=g:\temp
109 18006 [main] expr 2188 posify: env var converted to TMP=/cygdrive/g/temp
201 18207 [main] expr 2188 environ_init: 0x10010C98: TMP=/cygdrive/g/temp
202 18409 [main] expr 2188 environ_init: 0x10010DB8: USER=Administrator
212 18621 [main] expr 2188 environ_init: 0x10010DD0: USERDOMAIN=NEWELL
204 18825 [main] expr 2188 environ_init: 0x10010DE8: USERNAME=Administrator
208 19033 [main] expr 2188 environ_init: 0x10010E08: USERPROFILE=G:\Documents and Settings\Administrator
199 19232 [main] expr 2188 environ_init: 0x10010E40: WINDIR=G:\WIN2K
233 19465 [main] expr 2188 environ_init: 0x10010E58: _=/usr/bin/strace
235 19700 [main] expr 2188 environ_init: 0x10010E70: AC_SUB_CONFIGURE_ARGS= '--prefix=/opt/rtems-4.6' '--host=m68k-rtems' '--build=i686-pc-cygwin' '--target=m68k-rtems' '--disable-posix' '--disable-networking' '--disable-cxx' '--with-target-subdir=m68k-rtems' '--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin' 'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=efi332' 'RTEMS_CPU_MODEL=m68332' 'RTEMS_BSP_FAMILY=efi332' 'CPU_CFLAGS=-mcpu32' 'CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer' '--with-project-root=../../' '--enable-rtemsbsp=efi332'
219 19919 [main] expr 2188 environ_init: 0x10011080: BUILD_ALIAS=0
229 20148 [main] expr 2188 environ_init: 0x10011098: HOST_ALIAS=0
217 20365 [main] expr 2188 environ_init: 0x100110B0: TARGET_ALIAS=0
108 20473 [main] expr 2188 pinfo_init: pid 2188, pgid 2188
166 20639 [main] expr 2188 dtable::extend: size 32, fds 0x616D0CF8
134 20773 [main] expr 2188 normalize_posix_path: src /etc/passwd
111 20884 [main] expr 2188 normalize_posix_path: /etc/passwd = normalize_posix_path (/etc/passwd)
114 20998 [main] expr 2188 mount_info::conv_to_win32_path: conv_to_win32_path (/etc/passwd)
120 21118 [main] expr 2188 set_flags: flags: binary (0x2)
111 21229 [main] expr 2188 mount_info::conv_to_win32_path: src_path /etc/passwd, dst D:\cygwin\etc\passwd, flags 0xA, rc 0
167 21396 [main] expr 2188 symlink_info::check: not a symlink
109 21505 [main] expr 2188 symlink_info::check: 0 = symlink.check (D:\cygwin\etc\passwd, 0x22E978) (0xA)
119 21624 [main] expr 2188 path_conv::check: this->path(D:\cygwin\etc\passwd), has_acls(1)
214 21838 [main] expr 2188 etc::test_file_change: FindFirstFile succeeded
116 21954 [main] expr 2188 etc::test_file_change: fn[1] D:\cygwin\etc\passwd res 1
115 22069 [main] expr 2188 etc::init: fn[1] D:\cygwin\etc\passwd, curr_ix 1
110 22179 [main] expr 2188 pwdgrp::load: /etc/passwd
465 22644 [main] expr 2188 pwdgrp::load: /etc/passwd curr_lines 4
107 22751 [main] expr 2188 pwdgrp::load: /etc/passwd load succeeded
133 22884 [main] expr 2188 normalize_posix_path: src /etc/group
112 22996 [main] expr 2188 normalize_posix_path: /etc/group = normalize_posix_path (/etc/group)
120 23116 [main] expr 2188 mount_info::conv_to_win32_path: conv_to_win32_path (/etc/group)
130 23246 [main] expr 2188 set_flags: flags: binary (0x2)
106 23352 [main] expr 2188 mount_info::conv_to_win32_path: src_path /etc/group, dst D:\cygwin\etc\group, flags 0xA, rc 0
146 23498 [main] expr 2188 symlink_info::check: not a symlink
122 23620 [main] expr 2188 symlink_info::check: 0 = symlink.check (D:\cygwin\etc\group, 0x22E938) (0xA)
121 23741 [main] expr 2188 path_conv::check: this->path(D:\cygwin\etc\group), has_acls(1)
245 23986 [main] expr 2188 etc::test_file_change: FindFirstFile succeeded
113 24099 [main] expr 2188 etc::test_file_change: fn[2] D:\cygwin\etc\group res 1
114 24213 [main] expr 2188 etc::init: fn[2] D:\cygwin\etc\group, curr_ix 2
112 24325 [main] expr 2188 pwdgrp::load: /etc/group
410 24735 [main] expr 2188 pwdgrp::load: /etc/group curr_lines 8
108 24843 [main] expr 2188 pwdgrp::load: /etc/group load succeeded
118 24961 [main] expr 2188 cygheap_user::ontherange: what 2, pw 0x10011258
109 25070 [main] expr 2188 cygheap_user::ontherange: HOME is already in the environment /home/Administrator
616 25686 [main] expr 2188 sigproc_init: process/signal handling enabled(1)
392 26078 [main] expr 2188 build_argv: argv[0] = 'expr'
111 26189 [main] expr 2188 build_argv: argv[1] = 'xbuild_alias=i686-pc-cygwin'
106 26295 [main] expr 2188 build_argv: argv[2] = ':'
199 26494 [sig] expr 2188 wait_sig: entering ReadFile loop, readsig 0x2F8, myself->sendsig 0x2F0
357 26851 [main] expr 2188 normalize_posix_path: src .
122 26973 [main] expr 2188 cwdstuff::get: posix /build_09/m68k-rtems/c/efi332/exec
112 27085 [main] expr 2188 cwdstuff::get: (/build_09/m68k-rtems/c/efi332/exec) = cwdstuff::get (0x20EA88, 260, 1, 0), errno 0
121 27206 [main] expr 2188 normalize_posix_path: /build_09/m68k-rtems/c/efi332/exec/ = normalize_posix_path (.)
120 27326 [main] expr 2188 mount_info::conv_to_win32_path: conv_to_win32_path (/build_09/m68k-rtems/c/efi332/exec)
110 27436 [main] expr 2188 set_flags: flags: binary (0x2)
103 27539 [main] expr 2188 mount_info::conv_to_win32_path: src_path /build_09/m68k-rtems/c/efi332/exec, dst D:\cygwin\build_09\m68k-rtems\c\efi332\exec, flags 0xA, rc 0
185 27724 [main] expr 2188 symlink_info::check: not a symlink
112 27836 [main] expr 2188 symlink_info::check: 0 = symlink.check (D:\cygwin\build_09\m68k-rtems\c\efi332\exec, 0x20E748) (0xA)
108 27944 [main] expr 2188 path_conv::check: this->path(D:\cygwin\build_09\m68k-rtems\c\efi332\exec), has_acls(1)
135 28079 [main] expr 2188 build_fh_pc: fh 0x616D0E30
539 28618 [main] expr 2188 read_sd: file = D:\cygwin\build_09\m68k-rtems\c\efi332\exec: len=236
367 28985 [main] expr 2188 check_file_access: flags 4, ret 0
237 29222 [main] expr 2188 fhandler_base::fhaccess: returning 0
135 29357 [main] expr 2188 fhandler_disk_file::opendir: 0x10011538 = opendir (/build_09/m68k-rtems/c/efi332/exec)
223 29580 [main] expr 2188 fhandler_disk_file::readdir: 0x1001153C = readdir (0x10011538) (.)
139 29719 [main] expr 2188 fhandler_disk_file::readdir: 0x1001153C = readdir (0x10011538) (..)
170 29889 [main] expr 2188 fhandler_disk_file::readdir: 0x0 = readdir (0x10011538)
109 29998 [main] expr 2188 fhandler_disk_file::closedir: 0 = closedir (0x10011538)
424 30422 [main] expr 2188 closedir: 0 = closedir (0x212D20)
326 30748 [main] expr 2188 globify: argv[3] = 'x[^=]*=(.*)'
222 30970 [main] expr 2188 build_argv: argc 4
191 31161 [main] expr 2188 build_fh_pc: fh 0x616D0E30
167 31328 [main] expr 2188 open_shared: name (null), shared 0xA020000 (wanted 0xA020000), h 0x2E4
132 31460 [main] expr 2188 _pinfo::set_ctty: checking if /dev/tty-1 changed
100 31560 [main] expr 2188 _pinfo::set_ctty: attached tty1073741824 sid 2188, pid 2188, tty->pgid 2188, tty->sid 2188
128 31688 [main] expr 2188 _pinfo::set_ctty: resetting tty1073741824 sid. Was 2188, now 2188. pgid was 0, now 2188.
1519 33207 [main] expr 2188 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
161 33368 [main] expr 2188 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
111 33479 [main] expr 2188 fhandler_base::set_flags: filemode set to binary
290 33769 [main] expr 2188 fhandler_console::open: incremented open_fhs, now 1
107 33876 [main] expr 2188 fhandler_console::open: opened conin$ 0x3, conout$ 0x13
163 34039 [main] expr 2188 fhandler_console::output_tcsetattr: 0 = tcsetattr (,A020018) (ENABLE FLAGS 3) (lflag 107 oflag 9)
130 34169 [main] expr 2188 dtable::init_std_file_from_handle: fd 0, handle 0xB
158 34327 [main] expr 2188 build_fh_pc: fh 0x616D1038
107 34434 [main] expr 2188 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
111 34545 [main] expr 2188 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
114 34659 [main] expr 2188 fhandler_base::set_flags: filemode set to binary
108 34767 [main] expr 2188 fhandler_base::init: created new fhandler_base for handle 0x348, bin 1
122 34889 [main] expr 2188 dtable::init_std_file_from_handle: fd 1, handle 0x348
202 35091 [main] expr 2188 build_fh_pc: fh 0x616D1240
129 35220 [main] expr 2188 fhandler_base::set_flags: flags 0x10002, supplied_bin 0x0
99 35319 [main] expr 2188 fhandler_base::set_flags: O_TEXT/O_BINARY set in flags 0x10000
115 35434 [main] expr 2188 fhandler_base::set_flags: filemode set to binary
113 35547 [main] expr 2188 fhandler_base::init: created new fhandler_base for handle 0x2F4, bin 1
105 35652 [main] expr 2188 dtable::init_std_file_from_handle: fd 2, handle 0x2F4
574 36226 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin\cygiconv-2.dll, keep-rel, no-add-slash)
114 36340 [main] expr 2188 normalize_win32_path: D:\cygwin\bin\cygiconv-2.dll = normalize_win32_path (D:\cygwin\bin\cygiconv-2.dll)
113 36453 [main] expr 2188 mount_info::conv_to_posix_path: /usr/bin/cygiconv-2.dll = conv_to_posix_path (D:\cygwin\bin\cygiconv-2.dll)
500 36953 [main] expr 2188 mount_info::conv_to_posix_path: conv_to_posix_path (D:\cygwin\bin\cygintl-2.dll, keep-rel, no-add-slash)
114 37067 [main] expr 2188 normalize_win32_path: D:\cygwin\bin\cygintl-2.dll = normalize_win32_path (D:\cygwin\bin\cygintl-2.dll)
111 37178 [main] expr 2188 mount_info::conv_to_posix_path: /usr/bin/cygintl-2.dll = conv_to_posix_path (D:\cygwin\bin\cygintl-2.dll)
221 37399 [main] expr 2188 dll_crt0_1: user_data->main 0x401AE0
100 37499 [main] expr 2188 wait_for_sigthread: wait_sig_inited 0x30C
1850 39349 [main] expr 2188 fhandler_base::fstat: here
113 39462 [main] expr 2188 fstat64: 0 = fstat (1, 0x22EE90)
433 39895 [main] expr 2188 writev: writev (1, 0x22EEC0, 1)
111 40006 [main] expr 2188 fhandler_base::write: binary write
124 40130 [main] expr 2188 fhandler_base::write: 2 = write (0x10011690, 2)
147 40277 [main] expr 2188 writev: 2 = write (1, 0x22EEC0, 1), errno 0
118 40395 [main] expr 2188 close: close (1)
109 40504 [main] expr 2188 close: 0 = close (1)
555 41059 [main] expr 2188 do_exit: do_exit (1), exit_state 0
109 41168 [main] expr 2188 void: 0x0 = signal (20, 0x1)
110 41278 [main] expr 2188 void: 0x0 = signal (1, 0x1)
114 41392 [main] expr 2188 void: 0x0 = signal (2, 0x1)
100 41492 [main] expr 2188 void: 0x0 = signal (3, 0x1)
152 41644 [main] expr 2188 fhandler_console::close: decremented open_fhs, now 0
112 41756 [main] expr 2188 sigproc_terminate: entering
125 41881 [sig] expr 2188 wait_sig: done
2 41883 [main] expr 2188 proc_terminate: nchildren 0, nzombies 0
203 42086 [main] expr 2188 proc_terminate: leaving
-1 42085 [sig] expr 2188 _cygtls::remove: wait 0x0
487 42572 [main] expr 2188 __to_clock_t: dwHighDateTime 0, dwLowDateTime 156250
115 42687 [main] expr 2188 __to_clock_t: total 00000000 0000000F
120 42807 [main] expr 2188 __to_clock_t: dwHighDateTime 0, dwLowDateTime 156250
126 42933 [main] expr 2188 __to_clock_t: total 00000000 0000000F
860 43793 [main] expr 2188 _pinfo::exit: Calling ExitProcess 1
