cygwin build_alias issue (and a possible workaround...)
Scott Newell
newell at cei.net
Sat Sep 4 13:28:58 UTC 2004
At 06:23 AM 9/4/2004 , Bogdan Vacaliuc wrote:
>Question: do you get the ~/expr.log if you just type this in on the command
>line (with the script in place):
>$ expr "xbuild_alias" :
>".*[^_abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789]"
No log file is created for any of these cases:
$ /opt/rtems-4.6/bin/expr "xbuild_alias"
:".*[^_abcdefghijklmnopqrstuvwxyzABCDE
/usr/bin/expr: syntax error
: not found
: not found
: not found
$ /opt/rtems-4.6/bin/expr "xbuild_alias":
: not found
: not found
: not found
$ /opt/rtems-4.6/bin/expr "xbuild_alias" :
: not found
: not found
: not found
Now, if I add a line to the script such as:
echo "Calling expr with" "$@" >> ${HOME}/expr.log
I do get a logfile entry:
Calling expr with xbuild_alias :
Can you double check and see if I made an error doing the cut-n-paste of
your script? [attached].
>Hmm. Now that is a resource problem. Scott, what *are* the values for the
>SharedSection= of your "HKLM\SYSTEM\CurrentControlSet\Control\Session
>Manager\SubSystems\Windows" key? Mine are (currently):
>SharedSection=1024,3072,128,128
SharedSection=1024,3072,512,512
>Oh, ok, right. They were making it to expr ok, but expr wasn't doing the
>right thing...
>Its going to be a long weekend...
Absolutely.
newell
#!/bin/sh
if result=`/usr/bin/expr "$@"` ; then
??? echo "expr $@ result $result status 0" >> ${HOME}/expr.log
??? echo $result
??? exit 0;
else
??? echo "expr $@ result $result status !0" >> ${HOME}/expr.log
??? echo $result
??? exit 1;
fi
