cygwin build_alias issue (and a possible workaround...)
Bogdan Vacaliuc bvacaliuc at ngit.com
Sat Sep 4 15:35:06 UTC 2004
Hi Scott,
> I don't think it's the editor (UltraEdit), but the email
> client (Eudora). I noticed some 0xA0 bytes floating around,
> but not any 0x240 (odd--were you comparing wide chars,
Oops, I was sloppy.  I should have written (binary) 240; I just get so used
to that hex prefix...
I'm going to digest what you sent, but in the meantime, can you do one
thing?  Run a configure/build based on a clean (unmodified) source tree.  I
want to see what happens on your system without all the strace/sh -x
instrumentations.
> Odd that the strace'd expr call didn't get logged.  I'll run
> it through again with the strace call removed from cpukit/configure.
I have found that strace interferes with expr, such that the return value of
the pipeline which contains strace is always 0, triggering the failure in
the build scripts looking for a non-zero exit code to expr in certain places
(such as ours).
Thanks,
-bogdan
