RTEMS Evaluation CD Available
Jay Monkman jtm-list-rtems at smoothsmoothie.com
Thu Sep 9 14:28:20 UTC 2004
On Thu, Sep 09, 2004 at 07:09:57AM -0700, Till Straumann wrote:
> >I'm working under W2k, i. e. no mount options so far. W2K don't
> >support Rockridge Extensions (see
> >http://support.microsoft.com/?kbid=93604%22). Only plain ISO or
> >Joliet. MAy this be the problem?
> I suppose it could be. I tried to test the CD on Windoze yesterday but the
> machine I had access to had a broken CD player :-(. I'll check again
> today - however, the thing is of limited use under W2k anyways since the
> toolchain is built for a x86-linux host.
> Nevertheless, I'll see what I can do...
I ran into the same problem recently. When using mkisofs, you can add
'-J' to it's list of arguments, and the .iso should work with
Windows. According the mkisofs manpage, that may introduce
interoperability problems, though.
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20040909/caf94b68/attachment-0001.bin>
