Attachments and the rtems-users mailer...
Bogdan Vacaliuc
bvacaliuc at ngit.com
Mon Sep 13 03:31:41 UTC 2004
Hi Joel,
> > (The rtems list mailer keeps rejecting my posts due to the
> > attachments; and I havent figured out a better way to
> satisfy both the
> > rtems and cygwin mailers. Maybe I shouldn't cc: the lists...)
> There is a limit on the size of attachments to the RTEMS
> list. It is 100000 bytes. DId you trip it?
> You also have to send from a subscribed address.
No, the attachments were small, below are excerpts from the failure notice. I was attaching text files this time. My mailer
wrapped them into a octet-stream content type instead of text/plain. Earlier, it had rejected a tar.gz file for the same reason. I
switched preferences to uuencode and the rtems mailer liked that. Unfortunately, the cygwin archiver put the uuencode inline
instead of a link to the file, which was ugly in the archives. I went back to the default and decided to just reference the cygwin
archive this time.
If I had a better mail client [which shall remain nameless (as if you couldn't figure it out already... ;) ], I probably wouldn't
have these problems and be looking like a fool all the time.
I suppose there's a good reason for filtering out octet-stream attachments?
Thanks,
-bogdan
--- from the failure notice ---
Hi. This is the qmail-send program at rtems.com.
I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it
didn't work out.
<rtems-users at rtems.com>:
ezmlm-reject: fatal: Sorry, a message part has an unacceptable MIME Content-Type: application/octet-stream (#5.2.3)
--- Below this line is a copy of the message.
[snip]
This is a multi-part message in MIME format.
------=_NextPart_000_0152_01C49911.5A537850
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hello again,
[snip]
Content-Type: application/octet-stream;
name="test-configure"
Content-Disposition: attachment;
filename="test-configure"
#!/bin/sh=0A=
=0A=
[snip]
name="cygcheck.out"
filename="cygcheck.out"
[snip]
