telnetd
Fernando RUIZ CASAS
correo at fernando-ruiz.com
Mon Sep 20 10:34:54 UTC 2004
On Fri, 17 Sep 2004 11:28:30 -0500
"Joel Sherrill <joel at OARcorp.com>"
<joel.sherrill at OARcorp.com> wrote:
> Steve Holle wrote:
>> At 02:27 AM 9/17/2004, Fernando RUIZ CASAS wrote:
>>> Hi,
>>> But you must put attention.
>>> When the session is closed a delete_task_var in
>>>automatic free when
>>> close can crash the memory.
>>> This is a bad behavior for this option.
>> I'm not sure I quite understand your message. Am I
>>using the
>> rtems_initialize_telnetd(); incorrectly?
> When a task is deleted, the RTEMS task variable code
>calls a
> user provided destructor on the variable. The code in
>telnetd
> was not updated after it was changed (if I remember
>correctly)
> from a * to a ** passed in. I think that's what he is
>referring
> to.
>Fernando.. have you moved? I didn't remember you being
>in
>France.
Hi, I'm in France.
The comment is about a lot of changes had in the
libio_private_env.
The task var delete free option (destructor) in automatic
mode passed like parameter in the rtems_create_task_var
crash.
But this is a concern related by Till Staumam with his
telnetd V 1.1 and there he proposes an forever = TRUE in
order to avoid the system crash when the logout kill the
task and the task var variable (private session
environment).
See you.
>> I did get it to build, by the way, and I'm not sure how.
>>> See you.
>>> Fernando RUIZ.
>>> On Thu, 16 Sep 2004 12:06:03 -0500
>>>> Steve Holle wrote:
>>>>> Can anyone tell me how to enable telnetd ? I've used
>>>>>the same
>>>>> technique I used on the other network functions as shown
>>>>>in the code
>>>>> below :
>>>>> #ifdef ENABLE_NETWORKING
>>>>> std::cout << " Starting : Network
>>>>> Initialization..." << std::endl ;
>>>>> std::cout.flush() ;
>>>>> rtems_bsdnet_initialize_network ();
>>>>> std::cout << " Completed : Network
>>>>>Initialization."
>>>>> << std::endl << std::endl ;
>>>>> std::cout.flush() ;
>>>>> #endif
>>>>> #ifdef ENABLE_FTPD
>>>>> std::cout << " Starting : FTP
>>>>>Initialization..."
>>>>> << std::endl ;
>>>>> std::cout.flush() ;
>>>>> rtems_initialize_ftpd();
>>>>> std::cout << " Completed : FTP
>>>>>Initialization." <<
>>>>> std::endl ;
>>>>> std::cout.flush() ;
>>>>> unsigned long temp = (unsigned
>>>>>long)&TARFILE_SIZE ;
>>>>> status = Untar_FromMemory((unsigned char
>>>>> *)(&TARFILE_START), temp);
>>>>> #endif
>>>>> #ifdef ENABLE_WEB_SERVER
>>>>> std::cout << " Starting : Webserver
>>>>> std::cout.flush() ;
>>>>> rtems_initialize_webserver();
>>>>> std::cout << " Completed : Webserver
>>>>> Initialization." << std::endl ;
>>>>> std::cout.flush() ;
>>>>> #endif
>>>>> #ifdef ENABLE_TELNETD_SERVER
>>>>> int rtems_initialize_telnetd ( void ) ;
>>>>> std::cout << " Starting : Telnet
>>>>> std::cout.flush() ;
>>>>> std::cout << " Completed : Telnet
>>>>>Initialization."
>>>>> << std::endl ;
>>>>> std::cout.flush() ;
>>>>> #endif
>>>>> I can find the source for rtems_initialize_telnetd in
>>>>>the source
>>>>> tree but when I try to build I get the following error :
>>>>> C++ compiling /tcb2/source/BuildDateTime.cc...
>>>>> Creating tcb2-debug.elf (linking)...
>>>>> ConfigureNetwork.o: In function `ConfigureNetwork()':
>>>>> ConfigureNetwork.o(.text+0x654): undefined reference to
>>>>> `rtems_initialize_telnet
>>>>> d()'
>>>>> collect2: ld returned 1 exit status
>>>>> make[1]: *** [tcb2-debug.elf] Error 1
>>>>> make: *** [build] Error 2
>>>>> It appears that telnetd is not included in the rtems
>>>>>build but I
>>>>> can't figure out how to get it included.
>>>>> Any ideas?
>>>> None here. I just checked some build logs on the 4.6
>>>>tree and
>>>> telnetd.c is definitely being compiled. The call is
>>>>there.
>>>> Can you do something like this?
>>>> XXX-rtems-nm --extern-only .../librtemsbsp.a | grep
>>>>telnet
>>>> /opt/rtems-4.6/bin/mips-rtems-nm --extern-only
>>>> /opt/rtems-4.6/mips-rtems/jmr3904/lib/librtemsbsp.a |
>>>>grep telnet
>>>> telnetd.o:
>>>> 000002a0 T main_telnetd
>>>> 00000374 T register_telnetd
>>>> 000001b8 T rtems_initialize_telnetd
>>>> 00000000 T rtems_task_telnetd
>>>> 00000004 D telnetd_stack_size
>>>> 00000000 D telnetd_task_id
>>>> 00000008 D telnetd_task_priority
>>>> So that symbol is definitely in the mips/jmr3904 I had
>>>>installed.
>>>>> Steve Holle
>>>>> Link Communications, Inc.
>>>>> 1035 Cerise Rd.
>>>>> Billings, MT 59101
>>>>> sholle at link-comm.com
>>>> Joel Sherrill, Ph.D. Director of Research &
>>>>Development
>>>> joel at OARcorp.com On-Line Applications
>>>>Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>> 51, Le clos des G?ts
>>> Rue de la gare
>>> 69730 Genay
>>> France
>>> EMAIL: correo At fernando-ruiz Dot com
>> Steve Holle
>> 1035 Cerise Rd.
>> Billings, MT 59101
>Development
>Research
Rue de la gare
69730 Genay
France
