MicroMonitor TFS & RTEMS
    Till Straumann
    strauman at slac.stanford.edu
    Tue Sep 28 16:02:34 UTC 2004
Ed Sutter wrote:
>All,
>Last night I took Joel's advice (from a while ago) and used the
>tftpDriver.c code as a model for integrating TFS into RTEMS as
>a mountable FS.  I shamelessly reused a good portion of the
>generic parts of the code in tftpDriver.c (in places simply
>changing _tftp_ to _tfs_).  At first glance, it appears to be
>working fine, and now I can access TFS files through RTEMS's FS.
>So, assuming there must be more to it (it just can't be that easy!),
>what kind of limitations are imposed by this interface?  I see
>there is a limited number of interfaces (no ioctl, fstat,
>etc...), but I hope to eventually get that stuff working.
>Are there any other "gotchas" I need to be aware of for
>integrating TFS into RTEMS as a mountable FS?
I don't know TFS - it's desirable to support directory lookup and fstat.
Without
directories, 'pwd' won't work. Existing software often also uses seek.
-- T.
>Thanks
>Ed Sutter
