rtems on m5282lite
    g_YaneV
    g_yanev at bulpost.com
    Sat Apr  9 15:16:16 UTC 2005
  Hello,
 I have m5282LITE bord and I run successfully uclinux on it. But I need a real
time OS so I look in to rtems. In the CVS there is port to uCdimm board whit
the same processor(uC5282). I modify
c/src/lib/libbsp/m68k/uC5282/startup/linkcmds to correct the difference in
RAM/FLASH base and size, and the value of _DownloadLocation to match my
board. I set the UART speed to be 19200, and compile. I don't find any ather
difference between uC5282 and m5282LITE.
 But when I transfer any of the samples in my board RAM and execute them they
all start but after a short time  the board hang. I modify hello_world to be
a simple  loop from 1 to 1000 and each time to print the counter of the loop.
Each time i run this program it hang on different place(from 5-th to 50-th
printed messages).
 Where the problem can be? Can someone gave me any advice.
Regards,
Georgi
