MVME5500 PCI code update testing this weekend (was Re: PowerPC Burst PCI access)
Peter Dufault dufault at hda.com
Mon Apr 11 13:36:42 UTC 2005
On Apr 11, 2005, at 7:53 AM, Kate Feng wrote:
> ???  I am not rushing you, but I did not hear from you this weekend.
> Please send them to Joel,  Eric and Till when you are ready so that
> they
> can put it in the CVS.  When I need it, I will write it myself if not
> available.
I had to work over the weekend and I'm not sure when I'll get to it.
The changes to support the PMCSPAN are to recognize the DEC bridge
chip, map in the PCI memory assigned to the PMCSPAN memory in using
BAT5 similar to the other mappings, and count the PCI busses properly.
I'll send those diffs relative to what I changed.
Peter Dufault
HD Associates, Inc.
